Brake light question - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 05-09-2011, 11:56 AM Thread Starter
Andrew G's Avatar
I was hauling a load and being followed by a friend who pointed out that my brake lights are not overriding my flashers, so when I stop with my 4 ways on, I have no brake lights (the CHMSL still comes on, but the other 2 don't stop flashing). Is this normal for these trucks? I thought it was required that the brake lights take priority for these.
Not a panic situation, but I did a little research and couldn't find anything on it myself. Maybe someone else has dealt with this too...
99.5 F250 7.3 PSD Supercab Shortbed 4x4 on 315 75 16s
Front leveling springs, Hutch and Harpoon mods, A pillar 3 gauge pod with DiPricol Trans, Boost and EGT, Scangauge II, CNC Fab HPOP and HPX lines, Riffraff FRX, 2004 Heated and Lighted mirrors
Andrew G is offline
post #2 of 3 (permalink) Old 05-10-2011, 08:13 AM
Is this just on the trailer, or on the truck too? Do the trailer brake lights work when the flasher isn't on?
Lights to the trailer are fused, might be a bad fuse or two.
'00 F350 XLT, DRW, CC, 7.3 PSD, 6 speed, combo 90 gallon fuel tank/tool box, Banks Stinger-Plus, 203 T-stat, A-Pillar ISSPRO guages, Hadley Air horn, PowerSlide rear window, AIC, AIS, KCM S.S. HPX Line, Riffraff FRx.
Member # 10965
HorseHauler is offline
post #3 of 3 (permalink) Old 05-10-2011, 09:52 AM Thread Starter
Andrew G's Avatar
No trailer connected when it was noticed, just normal truck lights. Since then, I compared it to a 99 F150, which did the same thing - 4 ways override the brake lights for the rear lights, with the chmsl being the only brake indicator.
Andrew G is offline
