code for Keypad - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 07-27-2007, 06:36 AM Thread Starter
diesel dave 99's Avatar
code for Keypad
Hi I just got a 04 F-350 that has the key pad on the door for keless entry.
Where do I find the code?? someone said under the dash, I didnt see anything.
Or is there a way to program My owne code into it?
Thanks Dave
08 F-350 Crew Cab Dually 4X4 Lariat 6.4 4:10 gears. [email]
diesel dave 99 is offline
post #2 of 8 (permalink) Old 07-27-2007, 07:41 AM
Re: code for Keypad
Is it a stick on or is it built into the door? If it is part of the door than you need to have the dealer or someone with IDS/PDS to get it for you from the module.
sno_cat is offline
post #3 of 8 (permalink) Old 07-27-2007, 10:22 AM
My Photos: (6)
Re: code for Keypad
Usually there is a small plastic card with the factory code on it with the owner's manual and warranty stuff in the glove box. If you have this code then you can program your own code as well.
If you don't have this code then they will have to get it as the earlier poster described.
Good luck.
2015 F-150 CC 4x4 Platinum Ecoboost
2016 Explorer Platinum Ecoboost
2017 Fusion Titanium Ecoboost
pstroke is offline
post #4 of 8 (permalink) Old 07-27-2007, 06:45 PM
Re: code for Keypad
If you can find the reciever module , I have seen the number on a sticker
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer .Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
Special thanks to RacerX USA
action4478 is offline
post #5 of 8 (permalink) Old 07-28-2007, 10:11 AM Thread Starter
Re: code for Keypad
I had the last owners name on the title so I looked him up, he gave me the code. Now My question Is can I change it or would I have to have ford Change it Not that it matters He is In MO and Im in Pa LOL
post #6 of 8 (permalink) Old 07-28-2007, 11:42 AM
Re: code for Keypad
I think you can have two codes ,but I don't think you can change the original one.....
Rick.....
post #7 of 8 (permalink) Old 07-28-2007, 02:45 PM
2003f350's Avatar
Re: code for Keypad
I would think that it would work just like my wife's 04 Mercury Sable.
The manual reads to create your own personal code, use the following procedure
1. Enter the factory code, the drivers door will unlock.
2. Within 5 seconds, press the 1-2 on the keypad.
3. Enter your personal 5 digit code [Note] each number must be entered within 5 seconds of each other.
4.The doors will then lock then unlock, to confirm your new keycode.
You can not change the factory code, the factory code will still work in addition to your new code.
Ed [img]/ubbthreads/images/graemlins/smokin.gif[/img]
2003 F-350 Lariat Supercab 158" WB, 3.73 LS axle
7.3 PSD, auto trans. camper pkg. 12,500 lb. hitch,
adj. pedals. roof lights, Toreador Red, Arizona Beige, Power telescoping mirrors, and C-Betr mirrors. Delivery date Aug. 5, 2002. Reese 16K hitch, Thor Citation- model 29 5P 5th. wheel, Rhino liner.
2003f350 is offline
post #8 of 8 (permalink) Old 07-30-2007, 12:33 PM
Re: code for Keypad
You can have 2 different codes for locking/unlocking. 1 can be any code you want, the other code will never change, it is whatever Ford assigned to it originally. Look in the owners manual and it will tell you how to program them, along with your FOB's.
If you don't have that original code, check with the dealer and see if they can pull the code for you.
2004 F350, 6.0, crew cab, long box, ISSPRO BOOST-EGT-PYRO gauges, 4" MBRP exhaust, Innovative Diesel SCT programmed, GOS Racing headlight harness upgrade w/Bright Box FLC, husky floor mats, LEER canopy, FabTech 3.5" hangers on 35" tires.
2001 GMC Yukon, all stock besides the 18" chrome wheels and the kids car seats.
1992 Toyota Terdcel.
2006 Desert Fox toy hauler.
2005 Yamaha YFZ450 - a toy for the sand.
1996 Yamaha Banshee - oh yeah, it's a ride in the sand!
Richman is offline
