Developed a wobble - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 03-11-2019, 04:27 PM Thread Starter
Developed a wobble
While driving at any speed there is a wobble like an out of round tire. I believe it is the from the back tires (the steering wheel doesn't shake). At about 40-50 mph it literally shakes the truck. While it does wobble there is nothing like associated bearing noise. I checked the lugs the first thing. That is what it felt like the problem was Jacked it up and checked for bearing play. I will next go and check tire balance though it doesn't feel like that. About 30k miles ago I replaced the front wheel being assembly. In this years 4 wheel drive it is full replaceable unit. I haven't hit anything like deep pot holes. the worse thing is that it is getting worse.
Any ideas?
Late '99, F-250 7.3L, PSD, Super Duty, AT, 4X4, Crew Cab, 235 Mich tires, MBRP 4" Exhaust, 6-setting DP-Tuner (set for +80hp Econ mode), K&N Filter and Intake Tube, 203 thermostat, coolant filter, A-Pillar Isspro gauge set (pyro pre-turbo, trans temp, boost), Turbo Master Wastegate Controller, 6.0L tranny cooler, BTS valve body, rebuilt trans at 196K mi, bilstein shocks, HPOP rebuild, Fuel and oil crossover, Chevron Delo 400 10-40w, Zoodad mod, late model cup holder.
No time left for Drinking.
jdkluge is offline
post #2 of 7 (permalink) Old 03-11-2019, 04:55 PM
2000F250-7.3's Avatar
Check the wheels if you still have factory wheels they are hub centric and if the center has worn that could be part of the problem. You could try putting the rear wheels on the front as well
2000 F250 7.3 4inc exhaust, Ts 6 pos chip witch custom tunes, Built 4R100 w billet triple disc converter, 6.0 trans cooler and deep tans pan, CCV mod, 4 gauge pod A piller,Boost,Trans temp,EGT,fuel pressure AFE intake,RIFFRAFF Frx fuel Rail dead head fix black spring,High Flow banjo bolts,High Flow CVD Fitting, Harpoon mod,Diesel site adrenaline HPOP,AIH Plug,Plenum Reinforcing Inserts. FULL FORCE DIESEL STAGE 1.5 single shot injectors, Garrett powermax GTP38R and blank pedestal, RIFFRAFF Intercooler CAC Boots with complete clamp kit , scanegauge 2
2000F250-7.3 is offline
post #3 of 7 (permalink) Old 03-12-2019, 12:58 AM
Check the U-joints and carrier bearing, I had a tire tread let go last summer, it had intermittent wobble.
DENNY
1999 F350 AUTO 4x4 CC LB DRW 4.10
DENNY is offline
post #4 of 7 (permalink) Old 03-13-2019, 09:37 AM
69mach1377's Avatar
I once had a bad wobble that turned out to be a tire defect, a bubble formed on the inside and the tire needed replacement to fix it. Thought it was my diff at first.
2000 F250 XLT 4x4 SC 7.3 w/Auto Tranny w/ TC L/U Sw & shift kit, 3 autometer gages, Super Zoodad, PHP Hydra chip, 4" DP/Exhaust w/dual 3.5" outlets, 275/70/18 Kumho AT51s on 8.5" rims, 08 AlumDiffCvr, Bilsteins, 31 row trans cooler, WW, BPV delete, AIH delete, hutch, harpoon and billet FPR (70psi), trans cooler bypass delete by accident, rear air bags, Jimmijammers.
Jayco 26BHS elite, no RV parks...just the woods if possible.
See my album for a recent pic.
69mach1377 is offline
post #5 of 7 (permalink) Old 03-13-2019, 02:17 PM
klhansen's Avatar
My Photos: (180)
What Denny and 69mach1377 said about tire defects. I've had that happen as well. Definitely check the tires before you have a blowout.
), AIS,
regulated return,
klhansen is offline
post #6 of 7 (permalink) Old 03-15-2019, 12:54 PM
Check both front and back. Even though it seems as if it is coming from the back, sometimes it is hard to tell exactly where it is coming from; so check all four corners. Check tires for blebs, bubbles, nails, tread coming loose. Double check all lugnuts. Jack up each wheel and move each wheel side to side and up and down to check for any looseness. Also check behind the front wheels. There are some bolts that hold the wheels on. If those bolts come loose, a wheel may fall completely off.
2001 F350 XLT 4X4 crew cab, dual rear wheels, long bed, black, 7.3l turbo diesel, automatic transmission, 4.10, shift on the fly, running boards, sliding rear window, 38 gal fuel tank, Odyssey extreme 65-PC1750T batteries, Michelin LTX-MS2 rear tires, Sumitomo Encounter front tires, Shell Rotella Ultra elc, 11,500 gvwr, 20,000 gcwr, 7500 gvw, completely stock, 114,000 miles when purchased, now has 240,000 miles, repairs so far: two starters, batteries, cps, brakes, tires, alternator, ball joints, locking hub, wheel hub, AC compressor, serpentine belt, power steering pump, driver's side window, ignition switch, o-ring, Spectra premium radiator, water pump, fan clutch, fan blades, thermostat, thermostat housing, tensioner. Stolen twice so far, but recovered both times with major damage.
DonWarkentin is offline
post #7 of 7 (permalink) Old 03-20-2019, 06:14 PM Thread Starter
Yes it ended up being a tire delamination: bleb. You couldn't see it until the tire was off the ground and you could spin it. The tire was egg shaped. No bearing problems found. I saw the same problem on a different thread here. The tires have a good 70K miles. There are Michelins and have been good tires. I'll get another set this week. Costly fix but easy.
jdkluge is offline
Similar Threads
Truck in for P205C and Death Wobble lincster 6.7L Power Stroke Engine and Drivetrain 20 08-31-2017 01:53 PM
Death Wobble - Possible Resolution sidetrak06 1999-2007 Upgrades and Aftermarket - General 6 04-10-2015 08:37 PM
I eliminated the dreaded death wobble BeerSlayer Wheels, Tires, Brakes, and Suspension 0 07-06-2013 08:50 PM
dana 60 swap death wobble vashon7.3 7.3L IDI Diesels (Not Power Strokes) 4 04-22-2013 10:02 PM
Water Pump/Fan Pulley Wobble? dieselbeast 7.3L IDI Diesels (Not Power Strokes) 5 11-07-2011 04:34 PM
