Dies when push in cluch. Long crank time. - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 08-14-2019, 05:42 AM Thread Starter
Hello all. I have a 99 f250 with 7.3 manual 6 speed. I have long crank times plus dies sometimes when I push in clutch. Or tach will fall to 4 to 500 rpm then go back up. I have replaced icp,ipr,cps all from ford. I have new ad injectors a 120 volt icm. Batteries are putting out 14.2 volts. New ford starter. I have pulled tank changed screens. New Bosh fuel pump on rail new filter in bowl. Fresh oil as of 2 weeks ago. A friend has a snap on computer we have done buzz test all great. Only code is p0284. Ford tech said will get that code with the new grey cps. I have bought a second one from ford just to see if I had got a bad one. Any help is greatly appreciated. Plus 6 months ago I put new turbo in.
Dspeer is offline
post #2 of 7 (permalink) Old 08-14-2019, 10:53 AM
I think there is some kind of safety switch on the clutch pedal. I remember mine going bad at 10 below after work one day. crawl under the dash and see if it is loose.
DENNY
DENNY is offline
post #3 of 7 (permalink) Old 08-14-2019, 02:52 PM Thread Starter
Are you talking about the clutch pedal acuator sensor?
Dspeer is offline
post #4 of 7 (permalink) Old 08-14-2019, 09:18 PM
Yes that is the name of the thing. Do you have the long crank times when transmission is in neutral with clutch engaged?
DENNY
DENNY is offline
post #5 of 7 (permalink) Old 08-14-2019, 11:43 PM Thread Starter
Yes the warmer it is the more it dies. Dont matter if heavy throttle or slow in town. I can go drive it pull over unplug my icp it will idle up. I bought another one from ford same issue. I am stumped.
Dspeer is offline
post #6 of 7 (permalink) Old 08-15-2019, 10:56 AM
I have had trucks with the new CPS do the things you are seeing when the CPS is too close to cap profile ring "teeth". I have done wax check and used depth gauge and measured distance from flange to sensor end. You have to turn the crank with a breaker bar to get a tooth into the hole for the check. I think .020" is good but less than .010" gives troubles. I cut a paper shim and slide up the sensor to adjust. I guess too far out is bad too but I have not run into that.
2015 F350 Platinum Max Tow What a beast with the 4.30 gears!
2006 F450 CC Hauler bed 4x2 6.0 L 6.0 auto, Lariat, 4.30 r/a, SCT, 4in exh. 103K New heads to repair diesel in coolant, 148K.
2006 F350 Lariat CC Dually 4X2, 6.0 auto 4.10 LS, SCT, airbags, 4 in. exh. 154K Rebuilt engine to repair damage from burned piston. One head to fix fuel in oil problem.
35+5 foot double tandem axle flatbed trailer.
36 foot double tandem axle flatbed trailer
36 foot Platinum 6 horse LQ, side load, full width back tack
2003 EB Expedition 171K (no engine repairs, gas burners are the new longevity leaders)
2004 Volvo V70R AWD-high miler in fleet, 253K (no engine repairs) Hail totaled it but I kept it. Looks like a golf ball now.
Suzuki Carry KEI truck, 660cc 3 cyl DOHC EFI 4X4 5 speed RHD. Sort of a Smart Car sized pickup. Eats Gators and Mules for lunch.
jimmy is online now
post #7 of 7 (permalink) Old 08-15-2019, 05:32 PM Thread Starter
Ok thank you I will try on my next day.
Dspeer is offline
