Dusty desert engine bay, wash? - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 03-06-2019, 12:52 PM Thread Starter
JJEdwards's Avatar
Ok, I'm hesitant to ask this question because I think I know what I'm going to get...but here you go. How bad of an idea is it to wash a 7.3 engine bay that hasn't been gone over thoroughly first? i.e. wiring harnesses, pigtails, etc. Engine is in relatively perfect condition, no leaks, no codes, runs great, etc. It's just dirty. Is there any component of the engine I should completely avoid? I'm mostly worried about the electrical system.
Desert dust is starting to build up and I want to head this off sooner rather than later.
JARED
2000 7.3 PSD 4x4 Auto Trans., CC, short box 207,500 miles.
PHP Hydra, Bilstein 5100's, Bilstein steering stabilizers, Auto Meter 3 gauge pod--EGT, Trans Temp & Boost, Deep Trans Pan, Rotella ELC and T6 oil, DieselSite 203*, Riffraff Billet wheel, 4" turbo back MBRP 5" straight pipe, Donaldson 6637 blue, 20" Fuel wheels wrapped with 37" MT's
Security: Ravelco (for the pro's), Viper (for the rookies), The Club 1100 Steering Wheel Lock (visual deterrent).
JJEdwards is offline
post #2 of 6 (permalink) Old 03-06-2019, 01:26 PM
2000F250-7.3's Avatar
JARED
I would cover alternator and the fuse boxes on the drivers along with your air filter and just try and keep from spraying electrical connections directly I would just use garden hose pressure not a pressure washer.
2000 F250 7.3 4inc exhaust, Ts 6 pos chip witch custom tunes, Built 4R100 w billet triple disc converter, 6.0 trans cooler and deep tans pan, CCV mod, 4 gauge pod A piller,Boost,Trans temp,EGT,fuel pressure AFE intake,RIFFRAFF Frx fuel Rail dead head fix black spring,High Flow banjo bolts,High Flow CVD Fitting, Harpoon mod,Diesel site adrenaline HPOP,AIH Plug,Plenum Reinforcing Inserts. FULL FORCE DIESEL STAGE 1.5 single shot injectors, Garrett powermax GTP38R and blank pedestal, RIFFRAFF Intercooler CAC Boots with complete clamp kit , scanegauge 2
2000F250-7.3 is offline
post #3 of 6 (permalink) Old 03-07-2019, 10:16 AM Thread Starter
JJEdwards's Avatar
I appreciate the tips. I've washed other engine bays plenty before. I worry about my 7.3 after hearing enough instances of folks discovering water/moisture in an electrical connection that runs thinks afoul.
Jared
post #4 of 6 (permalink) Old 03-07-2019, 04:40 PM
ArcticDriver's Avatar
Dust is an issue in CO also. As long as its dry dust then I occasionally use compressed air.
Even if you have to wash areas where the dust is caked with oil/diesel, blowing off the dry dust first cuts down alot on the risk of saturating things you don’t to.
NOS Black CPS. ScanGauge-II. Bilstein 5100. Stancor GPR. Walker BTM. Noco Mod. Michelin Defender LTX 285/75/16.
SOLD:
ArcticDriver is offline
post #5 of 6 (permalink) Old 03-07-2019, 04:45 PM
I simple green it first cold let sit a bit then hose off let set a little then fire up and let get to temp never had a problem done this many times
redrocker is offline
post #6 of 6 (permalink) Old 04-15-2019, 09:40 PM
BroncoGlenn's Avatar
Now and again I’ll get to spraying it down with some purple power then putting a gentle stream on the engine bay. Don’t sit there and dig a hard steam of water into your connections and whatnot and you should be ok. Otherwise a higher volume with low pressure to rinse the crud off of everything.
Glenn
2002 F-350/XLT/PSD/SRW/CC/LB/4x4OR/Auto 233k miles
Ford AIS, Edge Insight CTS2 (no tunes), ceramic coated International bellowed up-pipes, RiffRaff billet wheel, EBPV delete pedestal/outlet, RiffRaff boot set, Turbo Master mechanical waste gate actuator, 6.0 trans cooler
BroncoGlenn is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Similar Threads
2011 Ford F-SERIES SUPER DUTY TECHNICAL SPECIFICATIONS HARLEY6LF250SDU 6.7L Power Stroke Engine and Drivetrain 6 03-14-2010 03:12 PM
Part number link genie144 Power Strokes 1994-1997 General 10 08-21-2009 03:08 PM
Injector Help and More? Ckill Power Strokes 1994-1997 General 12 02-24-2007 10:03 AM
