F350 4" blocks tepered or not? - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 07-10-2005, 05:31 PM Thread Starter
Are the rear lift blocks on a stock 05' F350 tapered or not?
05', F250, 4X4, crew cab, Flumoto valve, 2 1/2" leveling kit up front, 4" block in rear, 60 gallon aux. fuel tank / toolbox in bed. BFG 285\70\17 tires Rancho 5000 shocks. Firestone air bags.
tpace is offline
post #2 of 9 (permalink) Old 07-10-2005, 11:55 PM
Re: F350 4" blocks tepered or not?
dont think they are on crew cabs. ext cabs and reg cabs maybe because of the 1 piece driveshaft. crew cabs have 2-piece shafts with a carrier bearing to achieve the right angle...
mikeym is offline
post #3 of 9 (permalink) Old 07-11-2005, 09:03 PM
Crawl under your truck and look [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Jan 04 6.0 CC LB 4x4 Wedgwood blue
DR 6", 4.5 hanger + mini springs, TOYO 315/75 18's Fuel throttles.
rstaichi is offline
post #4 of 9 (permalink) Old 07-15-2005, 08:01 PM
i have an 05 f250 cc psd and i was going to put 350 blocks under my truck. i called suspension connection and they told me that i needed to buy the angled blocks. whether that is true, i don't know, but that is what i was told.
05 F-250 Lariat CC 4x4 Black and Silver
05pscc is offline
post #5 of 9 (permalink) Old 07-16-2005, 12:53 AM
I read on this site that you should replace tapered with tapered, and non with non.
I replaced my non tapered blocks (crew cab) with non tapered and experienced no vibration problems.
1MutCJ7 is offline
post #6 of 9 (permalink) Old 07-16-2005, 10:22 PM
well i don't know , but today i put 4" tapered blocks under my 05 f250 cc psd and i love it. the trucks rides and feels perfect. i ordered the daystar 2.5" leveling kit that will be installed next week. then after that it is tire time. i will let you know how my blocks are doing then. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
05pscc is offline
post #7 of 9 (permalink) Old 07-17-2005, 07:54 AM
where are you getting the blocks and u bolts Im assuming thats all you are changing
durantdiesel is offline
post #8 of 9 (permalink) Old 07-21-2005, 11:55 PM
I bought the blocks from my local suspension shop along with the new U-Bolts. I found out that you have to shim the carrier bearing. I don't know how much I have to shim yet but I have been told about an inch. Not a big deal. U-bolts and new shims ran me $100.
05pscc is offline
post #9 of 9 (permalink) Old 07-22-2005, 12:22 AM
if youve got a 2 piece driveshaft(crew cabs), youre better off with a flat block...
mikeym is offline
