??feels like it's miss firing?? - Diesel Forum - TheDieselStop.com
post #1 of 2 (permalink) Old 02-11-2019, 07:02 PM Thread Starter
Ok being a 6.0 diesel it idles fine it runs great but just sitting in park in can start pressing the pedal revving slowly and you feel something like a miss fire but goes away just as quick as it starts other than that it runs great mpg is 20 to 21 on hwy looking at everything on my torque app the numbers look good ficm is 49 to 49.5 ICP is ast 800 psi at idle just replace cam crank sensors. Does anyone have any ideas i have 175g on the clock.
Bluebyyou411 is offline
post #2 of 2 (permalink) Old 02-11-2019, 10:40 PM
klhansen's Avatar
My Photos: (180)
What engine?
You should put info about your truck in your signature. Click on User CP in the upper right and fill it out. That info will appear in all your posts.
), AIS,
regulated return,
klhansen is offline
Similar Threads
Help! Engine Miss Early 99 7.3. Marty_Graves '99 & up 7.3L Power Stroke Engine and Drivetrain 23 06-22-2012 05:49 PM
Engine has intermittent miss fire1 '99 & up 7.3L Power Stroke Engine and Drivetrain 5 09-20-2005 03:19 PM
Mild Firing miss.... CdnFirefighter Power Strokes 1994-1997 General 4 04-19-2005 12:21 AM
engine miss firing dowens '99 & up 7.3L Power Stroke Engine and Drivetrain 10 04-07-2005 09:12 AM
engine miss firing dowens 6.0L Power Stroke Engine and Drivetrain 0 04-05-2005 05:58 AM
