Fender Flares - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 06-07-2017, 09:34 AM Thread Starter
Fender Flares
I'm looking to cover up the Ford Cancer (rust) on my 04 F350 bed wheel wells. What is the best fender flares for the price and installation convenience?
Thanks!
Ping
2004 F-350 FX4 V10 Lariat SuperCab Torreador Red and Arizona Beige, Painted Lund Bug Deflector, Sun Visor, Side Window Cover, Side Window Visor, Taillight Covers and Rear Window Visor. Tilt-up Tonneau Cover. Ford Underrail Bed Liner w/ 1/2" Rubber Mat.(No Slippage) Stainless Billet Grill
Pinghr is offline
post #2 of 8 (permalink) Old 06-07-2017, 06:53 PM
klhansen's Avatar
My Photos: (180)
I have Bushwacker Street flares on my truck, but they fasten to the wheel opening with screws, so there needs to be enough good steel for the screws to stay in place. Rusted metal and or air doesn't have much holding power. Looks like they run about $500 for a set of 4, but if you browse around the internet, I think you can get something similar for way less. They're probably going to be offshore plastic stuff, but they'll probably serve to cover up your rust.
), AIS,
regulated return,
klhansen is offline
post #3 of 8 (permalink) Old 12-31-2018, 02:53 PM
Sorry to revive an old thread but I have a question about your fender flares Mr klhansen. Do they hold moisture or do they drain pretty well?
2001 Lariat, F250, 7.3, 6-speed, 3:73, Ford AIS, MBRP 4" turbo back, ATS ported housing, 205 t-stat, Infinity DX w/DP Tuner 80hp tow, coolant filter, Hutched & Harpooned, EGT & Boost gauge. Fuel Mavericks with 285/18, 86k miles(Jan-2017) Bought brand new April 2001.
aclasshog is offline
post #4 of 8 (permalink) Old 12-31-2018, 07:19 PM
I think all flares hold moisture to some extent.
2002 F350 7.3 psd supercab dually 2wd, AIS, Moog joints, Bilstein, Michelin Defender LTX, Dieselsite coolant filter, red ELC, prepump spin-on fuel filter, 254,500 miles, hutch/harpoon mod, marinco mod, scan gauge ll, Zoodad, Dieselsite boots, pedestal delete, CNC Fab w/ crossover oil lines, 6.0 trans cooler, replaced oil pan, Walker BTM, Denso starter
1974 CJ6 ... off the frame needs work
2013 Expedition... wife's car
Panhead ... 53 motor, 51 tanks, B grind cam, S&S carb, points, drum brakes ... It doesn't just sit in the garage
panhead george is offline
post #5 of 8 (permalink) Old 12-31-2018, 09:16 PM
ArcticDriver's Avatar
And if its a state that has snow and uses road salt then the flares make corrosion even worse.
SOLD:
ArcticDriver is offline
post #6 of 8 (permalink) Old 12-31-2018, 10:10 PM
That's why I don't use them.
2001 F350 XLT 4X4 crew cab, dual rear wheels, long bed, black, 7.3l turbo diesel, automatic transmission, 4.10, shift on the fly, running boards, sliding rear window, 38 gal fuel tank, Odyssey extreme 65-PC1750T batteries, Michelin LTX-MS2 rear tires, Sumitomo Encounter front tires, Shell Rotella Ultra elc, 11,500 gvwr, 20,000 gcwr, 7500 gvw, completely stock, 114,000 miles when purchased, now has 240,000 miles, repairs so far: two starters, batteries, cps, brakes, tires, alternator, ball joints, locking hub, wheel hub, AC compressor, serpentine belt, power steering pump, driver's side window, ignition switch, o-ring, Spectra premium radiator, water pump, fan clutch, fan blades, thermostat, thermostat housing, tensioner. Stolen twice so far, but recovered both times with major damage.
DonWarkentin is offline
post #7 of 8 (permalink) Old 01-01-2019, 02:08 AM
klhansen's Avatar
My Photos: (180)
Well, I'd had them on the truck since the summer after I got it, so 18 years now, and they haven't fallen off yet. But like the others said, they do hold some moisture.
), AIS,
regulated return,
klhansen is offline
post #8 of 8 (permalink) Old 01-01-2019, 05:59 AM
I think they also help to prevent tires from throwing stones on gravel roads or in States like AK that use small gravel for snowy roads.
SOLD:
