Help 6.0 wont start will crank but wont start!!!!!!!!!! - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 01-04-2019, 08:28 PM Thread Starter
Angry Help 6.0 wont start will crank but wont start!!!!!!!!!!
hey all i have a 2004 ford 250 6.0, 234xxx miles. just got fuel the other day kingsoopers, ever since then my truck has been running like **** since. Today on my way to work it died and wouldnt start back up could crank it but wouldnt start. no check engine light. pulled fuel filter and smelled amonia not diesel. looks watery. probably a bad back of fuel!?!?!?!?!?!?!?!
Dieseld67 is offline
post #2 of 3 (permalink) Old 01-04-2019, 09:00 PM
79jasper's Avatar
Could be algae.
Drain some into a clear container and get some pictures.
I would talk to the station.
Sent from my SM-N960U using Tapatalk
79jasper is offline
post #3 of 3 (permalink) Old 01-04-2019, 11:02 PM
ArcticDriver's Avatar
Ammonia?
Are you sure you didn’t use a DPF fluid? Urea can smell like Ammonia as it breaks down.
When you say it looks watery, what do you mean?
As suggested, drain your fuel filter bowl into a clear glass jar and the water should settle out below the fuel. It will be a distinct layer.
SOLD:
ArcticDriver is offline
