how we run 2 stroke in the 7.3s fuel - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 05-08-2019, 09:59 PM Thread Starter
Texas_proud77836's Avatar
I don’t remember the ratio anymore, I sorta stopped doing it and forgot why we did it. I think for lubrication because the new diesel doesn’t have it anymore.
Would it be alright to run that 2 stroke mixture in a old 83 John deer. 32 gallon fuel tank so about the same as my duallys. Just got the old thing, want to treat it right till the new wears off. The dually is up for a oil change as well so i finally have enough diesel equipment to get the 5 gallon bucket sales. While the 7.3 doesn’t burn oil that old tractor does. Can’t find the oil capacity online but I’m gonna run some Lucas in it for giggles.
So I guess my question was just ratio. I forgot.
Maybe ratio on Lucas to oil. If it takes more then a quart. I think the 7.3 was 12 quarts. Idk what the 5.9 John deer motor is yet.
Texas_proud77836 is offline
post #2 of 7 (permalink) Old 05-08-2019, 10:49 PM
Big Horn's Avatar
I had asked about ratio some time back for my 7.3 and RT had suggested that him and a lot of others add 1 qt. of the Wallyworld 2 stroke oil to a tank of diesel. Thats what I’ve been doing and it is running great.
2002 F350 7.3L / 4R100 - 4WD CC DRW 8 Box, AIH Delete, Gauges- Pyro, Trans Temp, Boost, Fuel Pressure, TS-6 tuner, Zoodad Mod, Mishimoto 31 row Trans cooler, Mobil 1 ATF, Trans return line ATF filter, Hutch/Harpoon Mod, Air Lift Load Lifter 5000 rear air springs, Rancho 9000 shocks, Timbrens on the front.
Big Horn is offline
post #3 of 7 (permalink) Old 05-09-2019, 04:56 AM
ArcticDriver's Avatar
I would not run Lucas in anything. I don’t recall ever reading anything positive about their products.
Your JD would like 2-cycle oil.
You could run a minimum Biodiesel blend if you wanted to clean the fuel system. (B5-B11).
NOS Black CPS. ScanGauge-II. Bilstein 5100. Stancor GPR. Walker BTM. Noco Mod. Michelin Defender LTX 285/75/16.
SOLD:
ArcticDriver is online now
post #4 of 7 (permalink) Old 05-09-2019, 11:04 AM Thread Starter
I stayed up late last night reading. People really just say Lucas oil is to thick and can cause warmer oil temps, they had stats on it and It’s probably right, so here’s my story. I ran seafoam in my motors oil on 2 trucks. Later after changing oil and draining the old with seafoam I’ve got a tick on first start up... both trucks. I had a quart a Lucas someone gave me and put it in one truck and it did stop the tick.... but honestly I’d say not to run no additives in oil. Never start that just run your oil.
post #5 of 7 (permalink) Old 05-10-2019, 02:25 AM
Thats my thought as well.
SOLD:
post #6 of 7 (permalink) Old 06-13-2019, 10:18 AM
Im not an engineer and dont have enough money to act like I am.
early 99, cone intake, stock 3.5" exhaust, muffler deleted. Edge Evolution CS
Barchetta is offline
post #7 of 7 (permalink) Old 06-13-2019, 10:36 AM
Just add a quart of two stroke water cooled oil per tankful.
2006 F250 Lariat Supercrew, ESOF 4x4, 18" tires, FX 4, HD Alt., block heater, Integrated Trailer Brake Controller, Upfitters, power rear window, cab lights - delivered 10/25/05
Ford Remote Start; High idle mod; Timbren load levelers, Scangauge II, Blue Spring upgrade, Quick Start 200 amp large frame alternator, 2 batteries January 2010; GPCM replace October 2011; 2 EGR valves; EGR Cooler replaced 12/30/11; Performance Machine & Mfg. coolant filter added 1/2/12; Rotella T6 5W40 oil; turned rotors, replaced brake pads for 1st time 1/7/12 101K miles; GPCM, both subharnesses and all 8 glowplugs replaced 1/5/13 at 118,000 miles; 2 Ford batteries replaced under battery warranty twice, the latest 9/18/2015; FICM power supply board replaced with Dorman board 11/20/13. Coolant flushed and replaced with Prestone ELC 9/27/14. STC fitting 10/19/14; Dummy Plugs 11/8/14; Turbo rebuilt 11/29/14; cold side CAC tube and boots replaced with metal tube 1/24/15; replaced hot side boots 1/30/16.
Ford06 is offline
Similar Threads
7.3L acts like its running out of fuel DAVID A SINK '99 & up 7.3L Power Stroke Engine and Drivetrain 18 01-08-2018 06:31 PM
International and Ford parts list Excavator '99 & up 7.3L Power Stroke Engine and Drivetrain 3 04-01-2015 10:17 AM
ULSD Fuel calico5string General Diesel 84 06-01-2014 09:03 AM
What to add to fuel for lubrication??? HorsePilot General Diesel 9 05-25-2010 02:36 PM
fuel pressure Wayne Saunders '99 & up Upgrades and Aftermarket - 7.3L Engine 12 12-28-2007 12:17 PM
