HVAC problems , blower? - Diesel Forum - TheDieselStop.com
post #1 of 2 (permalink) Old 12-19-2018, 09:16 AM Thread Starter
I've had an issue with the amount of air coming out of my vents ... when driving with it on high it will get down to blowing almost nothing. When I move the position switch it will switch thru perfectly fine .. I've replaced the blower fan , resistor, replaced the climate control face plate and all the switches behind
Any ideas?
Maybe the vacuum pump ? Or the check valve?
M
Davismx is offline
post #2 of 2 (permalink) Old 12-19-2018, 10:33 AM
My A/C wasn't blowing out the front vents only the defrost vents so I replaced the vacuum pump and that fixed the problem good luck MERRY CHRISTMAS
redrocker is offline
