Ignition key won't turn!! - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 12-16-2007, 12:41 PM Thread Starter
Whent out to start the truck this morning and my key will not turn!! Even if you take the tension off the steering wheel it will not turn.. [censored]!
Any suggestions?
2002 F-350 7.3 PSD Lariat,
Rancho Lift W/RS 9000's
Ride Rite air bag suspension in rear
MagnaFlow 4" Turbo back exhaust
AutoMeter guages
Banks Trancommand
10K Mod
CCV Mod
Bully Dog Power Pup Programer
K&N Air Intake
T/C Lockup Indicator Light
Wicked Wheel
jeffhask is offline
post #2 of 13 (permalink) Old 12-16-2007, 02:02 PM
Cool_Canuck's Avatar
My Photos: (12)
re: Ignition key won't turn!!
Got the right Key??
Squirt some WD40 in there, run the key in and out a few times.
Might be able to pull the tumbler out but if it's the key not setting correctly, that won't happen either.
2011 f250 XLT 4X4 Crew Cab.
SOLD - 2001 F250 XLT 7.3L SC/SB 4x4 (ESOF) - Tranny Upgrades; SCMT 1705; AIS Intake w/
; ZooDad; Turbo back 4" Exhaust; Issopro Pillar Mount Gauges; TC lockup LED;
Cool_Canuck is offline
post #3 of 13 (permalink) Old 12-16-2007, 02:53 PM
Try pushing up on the shift lever a little as you turn the key.
1997 F350 Crew Cab Long Bed. Auto with 410 Rear End. Ranch Hands., trany temp gage and K&N air filter Pretty much stock pulling a 10,000lb Fifth Wheel and a 16' boat tagging along.
Rambleon is offline
post #4 of 13 (permalink) Old 12-16-2007, 03:16 PM
Make sure there is no tension on the steering wheel and then try to turn the key to accessory. Then try turning to run. Do this three or four times and it will let go (MAYBE).
Joe
2002 F350, Crew Cab, 4WD, ISSOPRO Gauges,
3.73, Auto, 2wd low range mod, No door dinger,
Interior lights off switch, Zoodad Mod,
Extra Trans Cooler, Before coolers trans fltr,
Coolant fltr, Crimestopper remote start/alarm
Oil Guard Bypass, Air horns
MOUNTAINMAN444 is offline
post #5 of 13 (permalink) Old 12-17-2007, 09:22 AM
Swellmel's Avatar
Turn the key over, double cut keys sometimes fit funny
2002
F350 Red PSD Auto SC/LB SRW 4x4 Tymar Intake 4"Dual Exhaust DI 6 position twisty knob BTS 4R100 Vegistroke V3
Swellmel is offline
post #6 of 13 (permalink) Old 12-17-2007, 03:42 PM
WD40?
1999 F250 2WD RC/LB posi AIS, Superchips DPI propane, 4" turboback exhaust, gauges, Edge Evolution tuner [looking into a Propane chip]
SMOKESKULL is offline
post #7 of 13 (permalink) Old 12-18-2007, 06:41 PM
Mine has done that a couple of time if I shut the truck off with the wheels turned.
First time I jacked the front off the ground to get it to turn.
The other time I pulled the steering wheel hard to one side and that worked. A PIA either way.
2OOO F-250 4WD Crew Cab, 267,000K miles,
Stock. Replaced #1 Injector/harness, Starter Relay,CPS(twice), GPR, VSS, S-Belt, Alternator, H2O Pump. AIS Severe Duty Filter, Bilsteins, Heater shutoff valve, Rotella Syn, Nitto TG's 305/55 on Eagle 20x10's, Mobil 1 ATF,Walker BTM, Mesa, Arizona
PRDATR is offline
post #8 of 13 (permalink) Old 12-18-2007, 09:26 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: jeffhask</div><div class="ubbcode-body">Whent out to start the truck this morning and my key will not turn!! Even if you take the tension off the steering wheel it will not turn.. [censored]!
Any suggestions? </div></div>
Jeff, post back and let us know how you got it to let go. Surely it's not still sitting there locked up.
Joe
post #9 of 13 (permalink) Old 06-23-2017, 12:59 PM
oilcan1001's Avatar
Guess this never got resolved ?
2001 F-350 Lariat 4x4
CC, SRW, LB, AT
New radiator
6.0 OEM 26 row trans cooler
AIS intake
Edge Insight
Hydra with stock PHP tunes
2004 Sandpiper by Forest River - 11,000 lbs fully loaded
Andersen Ultimate 5th Wheel Hitch
oilcan1001 is offline
post #10 of 13 (permalink) Old 06-23-2017, 01:56 PM
Relentless007's Avatar
after ten years . . . yeah I think we can give up on this one.
1997 F250 Heavy Duty 7.3 Powerstroke 4x4 Crew Cab, SRW, Automatic E40D
BTS Valve Body
Tru-Cool Trans Cooler
4" Turbo Back Diamond Eye Stainless Exhaust
Tymar Air Intake
TS Six Position Chip (stock,High Idle, +50, +75, +100, +120)
Tymar HPX line in hand but no installed yet
285/75r16 BFG All-Terrain KO2
ARE LSII Custom Color Tonneau bed cover
Color match Rhino spray in bed liner
Better To Be Tried By 12 Than Carried By 6
Relentless007 is offline
post #11 of 13 (permalink) Old 06-23-2017, 02:05 PM
oilcan1001's Avatar
Similar post on ps.org 6yrs old, I got a reply today from OP,
CC, SRW, LB, AT
New radiator
AIS intake
Edge Insight
post #12 of 13 (permalink) Old 06-29-2017, 12:58 PM
What was the response?
2006 F250 Lariat Supercrew, ESOF 4x4, 18" tires, FX 4, HD Alt., block heater, Integrated Trailer Brake Controller, Upfitters, power rear window, cab lights - delivered 10/25/05
Ford Remote Start; High idle mod; Timbren load levelers, Scangauge II, Blue Spring upgrade, Quick Start 200 amp large frame alternator, 2 batteries January 2010; GPCM replace October 2011; 2 EGR valves; EGR Cooler replaced 12/30/11; Performance Machine & Mfg. coolant filter added 1/2/12; Rotella T6 5W40 oil; turned rotors, replaced brake pads for 1st time 1/7/12 101K miles; GPCM, both subharnesses and all 8 glowplugs replaced 1/5/13 at 118,000 miles; 2 Ford batteries replaced under battery warranty twice, the latest 9/18/2015; FICM power supply board replaced with Dorman board 11/20/13. Coolant flushed and replaced with Prestone ELC 9/27/14. STC fitting 10/19/14; Dummy Plugs 11/8/14; Turbo rebuilt 11/29/14; cold side CAC tube and boots replaced with metal tube 1/24/15; replaced hot side boots 1/30/16.
Ford06 is offline
post #13 of 13 (permalink) Old 06-29-2017, 04:05 PM
oilcan1001's Avatar
Holy thread resurrection batman! The problem with my truck turned out to be a worn out key. I had a locksmith cut me a new key... not copy my existing key, but cut a new key to the correct depth like a brand new key and boom everything worked and it easily rolled back into ACC mode with no problems. There are two ways to do this, a dealership may be able to get you the code based on your VIN if you can provide proof of ownership, or a good locksmith should be able to cut you a new key to spec... no clue how they do it, but the locksmith did it for me. Best of luck and hope this helps!
I actually went to my local dealer and they said they only keep key records for like 10 yrs so SOL.
I asked a locksmith and he said cost would be about $50. I just havent pulled the trigger yet.
CC, SRW, LB, AT
New radiator
AIS intake
Edge Insight
