Keeping a 7.3 on "on" mode - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 09-09-2019, 05:40 PM Thread Starter
I have a 1999 f250 7.3 XLT model, can I leave it on the "on" mode where the glow plugs heat up? Will this fry my glow plugs if I do this? Thanks! Any quick response is appreciated I'm trying to tune it right now.
Forester121 is offline
post #2 of 3 (permalink) Old 09-09-2019, 06:34 PM
klhansen's Avatar
My Photos: (180)
If you're talking about checking things out with the key in run position, that's not a problem. The glow plugs are controlled to be on for a maximum of 2 minutes, depending on oil temperature. And that only happens when the oil is COLD. At normal daytime temps now, they're on for a much shorter time. Once the oil temp is 140F, they don't even come on.
), AIS,
regulated return,
klhansen is offline
post #3 of 3 (permalink) Old 09-09-2019, 08:48 PM Thread Starter
Thanks! I was putting a tune on my truck and I wanted to make sure it wasn't going to fry them while it was on the run position.
