Keyless Remote Key Fob - Diesel Forum - TheDieselStop.com
 3Likes
  • 1 Post By Ford06
  • 1 Post By f350jeeper
  • 1 Post By klhansen
post #1 of 11 (permalink) Old 05-01-2018, 06:24 PM Thread Starter
ArcticDriver's Avatar
My original Ford key fob broke where it attached to the key ring and all of them I find listed online are after-market and have many negative feedbacks of button failure within a few weeks of purchase.
I can't find the genuine Motorcraft on the Ford website.
Any suggestions? Any after-market brand you would recommend?
And lastly, I have another F250 that does not have the keyless remote system installed in the truck. Is it possible to fit a new one in ? I thought there was a recent thread on this very topic but I can't find it.
SOLD:
ArcticDriver is offline
post #2 of 11 (permalink) Old 05-02-2018, 08:32 AM Thread Starter
Found Part Number on back of fob:
3B:F87B-15K601-AA Factory OEM KEY FOB Keyless Entry Remote Alarm
Found them used on Amazon for $10.
Most feedback I have read for after-market products has been of failure within weeks of purchase.
By using the P/N above, you can hopefully find the original OEM.
SOLD:
post #3 of 11 (permalink) Old 05-02-2018, 08:38 AM Thread Starter
Still trying to determine if I can add a genuine Ford Motorcraft receiver to a 2002 that did not come with keyless remote from the factory.
Is it just a matter of "plug & play" into existing wiring or is there actually something in the PCM?
SOLD:
post #4 of 11 (permalink) Old 05-02-2018, 03:55 PM
i GOT ONE FROM REMORTES UNLIMITED TO REPLACE THE FOB ON MY fORD ADD ON ALARM/REMOTE START FROM 2006. I have had it for over a year and it works OK. I think they also offer shells to put your guts in.
Sorry for the caps but I don't feel like retyping it. This is mine: RemotesUnlimited.com
ArcticDriver likes this.
2006 F250 Lariat Supercrew, ESOF 4x4, 18" tires, FX 4, HD Alt., block heater, Integrated Trailer Brake Controller, Upfitters, power rear window, cab lights - delivered 10/25/05
Ford Remote Start; High idle mod; Timbren load levelers, Scangauge II, Blue Spring upgrade, Quick Start 200 amp large frame alternator, 2 batteries January 2010; GPCM replace October 2011; 2 EGR valves; EGR Cooler replaced 12/30/11; Performance Machine & Mfg. coolant filter added 1/2/12; Rotella T6 5W40 oil; turned rotors, replaced brake pads for 1st time 1/7/12 101K miles; GPCM, both subharnesses and all 8 glowplugs replaced 1/5/13 at 118,000 miles; 2 Ford batteries replaced under battery warranty twice, the latest 9/18/2015; FICM power supply board replaced with Dorman board 11/20/13. Coolant flushed and replaced with Prestone ELC 9/27/14. STC fitting 10/19/14; Dummy Plugs 11/8/14; Turbo rebuilt 11/29/14; cold side CAC tube and boots replaced with metal tube 1/24/15; replaced hot side boots 1/30/16.
Ford06 is offline
post #5 of 11 (permalink) Old 05-02-2018, 04:47 PM Thread Starter
Thanks.
I am interested in details of your Ford Add-on Remote Start...is it a Motorcraft product?
SOLD:
post #6 of 11 (permalink) Old 05-03-2018, 03:25 PM
Yes it was. I think it may have been made for Motorcraft by Code Alarm, but I cannot swear to it. it was a tough install because it is also a security system. I had to cut into the wiring in the driver's door as well as under the dash and under the door sill. I am used to working on boats though so all connections were soldered and heatshrink protected with the sealant inside. No problems with it in 12 years, so I must have doen it right. Hard part was figuring out the wiring, since the wiring harnesses changed in '05 II think). Overall it has been a great system.
Ford06 is offline
post #7 of 11 (permalink) Old 05-12-2018, 11:05 PM
Arrow Ordered and programmed these with no issues for our 2004 Excursion 6.0L XLT
We purchased a pair of replacement 3-button fob transmitters that go with the chipped key on our 2004 Excursion from vendor keyess2go on Amazon for less than $10 ("Keyless2Go Keyless Entry Car Key Fob Replacement for Vehicles That Use 3 Button CWTWB1U331").
You can also get the chipped key blanks via Amazon ("Keyless2Go New Uncut Replacement Transponder Ignition Car Key H72") for $8.95 each. You will have to get the metal key portion cut at a keyshop, locksmith, or a home center that cuts keys. We had it done at a big box home center ("HD") , paying for a "dumb key" blank cutting, but had employee use the blank chipped key instead.
The programming instructions for new keys and fobs are in your owners manual - these were for our 2004 Excursion:
Programming Chipped 2004 Excursion Key with 2 original keys
Can I program a third key myself if I have two working keys?
Yes, once you have had the new key cut by a Locksmith
or other qualified persons use the following instructions.
1. Insert an existing working key into the ignition cylinder.
2. Turn the ignition cylinder to ON (RUN) and back to OFF.
3. Remove the existing working key and, within five seconds, insert a second working
key and turn it to ON (RUN) then back OFF.
4. Remove second working key and insert the new key before ten seconds have
elapsed and turn it to ON (RUN). Leave it on for one second and turn back to OFF.
5. The security light will light up for three seconds to indicate that the new
key has been successfully programmed.
Name:	Ford 3 Button Fobs.jpeg
Name:	Ford Chipped key.jpg
'16 F350 Dually Crew Cab Long Bed, '04 Excursion Diesel
'17 JKU Rubi Recon & '74 CJ-5, LS TLB, Vermeer RT450
MILVETS Living the Life in Arizona High Country
f350jeeper is offline
post #8 of 11 (permalink) Old 05-12-2018, 11:23 PM
klhansen's Avatar
My Photos: (180)
Adding RKE to a non-RKE truck would entail replacing the VSM on an '02. On '99-'01 trucks that function is built into the GEM, and that would have to be swapped out as far as I know.
), AIS,
regulated return,
klhansen is offline
post #9 of 11 (permalink) Old 05-13-2018, 09:01 AM Thread Starter
Thank you for this information. It gives me a starting point to research.
It looks like new VSMs are $200-$250 and they require a flash by Ford for maybe $100 more.
After that is complete then the only step is programming the 3-button fobs.
Does that sound right?
SOLD:
post #10 of 11 (permalink) Old 05-13-2018, 04:00 PM
klhansen's Avatar
My Photos: (180)
Sounds like it would work to me. You might PM ford_doctor and see if he has some additional insight, since he's a Ford tech.
), AIS,
regulated return,
klhansen is offline
post #11 of 11 (permalink) Old 05-20-2018, 09:54 AM
Texas_proud77836's Avatar
I’ve been watching the viper security system on eBay for awhile now for my gmc stepside. Has Remote start and comes with 1 lcd key rechargeable key fob and one regular one. I watched a video, it didn’t look to hard to instal and cost 300.
I’d consider it for my dually but it’s a standard and not a very fast truck. Doubt anyone could get far in it by the time I dailed 911 lol
Texas_proud77836 is offline
