Limited arm rest on Excursion - Diesel Forum - TheDieselStop.com
post #1 of 2 (permalink) Old 07-21-2005, 10:31 PM Thread Starter
I just thought I would share a simple discovery. My 140,000 mile 2000 model Excursion Limited was starting to show cracks and wear on the driver's arm rest. While trying to figure out how to take the arm rest OFF, I found out you can pull the cover off from the rear, by the hinge, and roll it inside out like a sock. I switched the drivers one with the passenger one and now the worn damaged part faces down. I am good for another 140,000 miles.
gfaub is offline
post #2 of 2 (permalink) Old 07-22-2005, 11:22 AM
Re: Limited arm rest on Excursion
Thanks for the tip.
I will check it out this weekend.
Mine just took a dive on me the other day.
99 F250 SD 4x4, Bilstein, Mag HyTech Diff. cover and trans. cover, BFG AT KO, Husky mats, LoJack, AFE air intake, Jardine 4" Exhaust/Magnaflow muffler, Pillar mount with Autometer gauges, Wet Okole, SCMT. HX mod, Pre-pump mod.
2000 Excursion V10, Mag Hi-Tech covers
John H is offline
