Mystery leak? - Diesel Forum - TheDieselStop.com
 1Likes
post #1 of 19 (permalink) Old 01-21-2016, 07:14 AM Thread Starter
Usmc1968's Avatar
Mystery leak?
Greetings,
So, I found a spot of oil on the floor of my barn. Clear oil coming from this (picture attached). Would this be the Torque converter? If it is how big of a pain are they to fix?
Thanks!
Semper Fi
2000 F250 7.3 CC
"It does not require a majority to prevail, but rather an irate, tireless minority keen to set brush fires in people's minds."
Samuel Adams
Usmc1968 is offline
post #2 of 19 (permalink) Old 01-22-2016, 03:22 PM Thread Starter
Usmc1968's Avatar
Here is the picture
Samuel Adams
Usmc1968 is offline
post #3 of 19 (permalink) Old 01-22-2016, 03:27 PM
RT
RT's Avatar
The valley of the engine has a drain in the rear that will cause leaks from the top of the engine to drain down the back just like you are experiencing. Many a naive mechanic has replaced the rear main seal only to discover that wasn't the source. Get up top and see if you have a leaking HPOP or turbo. Could even be a fuel leak. The torque converter would bleed red.
RT is offline
post #4 of 19 (permalink) Old 01-22-2016, 03:56 PM Thread Starter
Usmc1968's Avatar
Ok, great thank you RT! It is clear and oily with no smell. Almost looks like the brake fluid coming out of my wiring harness by the Master Cylinder (taking it to Ford ASAP for the recall). I will go out and check it out as soon as this blizzard is over!!!
Semper Fidelis
Samuel Adams
Usmc1968 is offline
post #5 of 19 (permalink) Old 01-22-2016, 07:15 PM
bugman's Avatar
My Photos: (12)
How is your ail conditioning? It could be oil from the refrigerant.
bugman is offline
post #6 of 19 (permalink) Old 01-22-2016, 07:20 PM
RT
RT's Avatar
Out of the back of the motor? Kind of a circuitous route.
RT is offline
post #7 of 19 (permalink) Old 01-23-2016, 08:04 AM Thread Starter
Usmc1968's Avatar
Have not checked the AC yet, it is 20 here with Blizzard conditions here in Maryland. As soon as I can get to the barn I will check all of the above
Thanks!
Semper Fidelis
Samuel Adams
Usmc1968 is offline
post #8 of 19 (permalink) Old 02-07-2016, 01:09 PM Thread Starter
Usmc1968's Avatar
Update,
When I checked the Vally of the engine I found some pools of Diesel. I suspected the fuel bowl valve gaskets but when I turned the truck on and off over the past few days I found this leaking (picture attached). When I tried to tighten it up a bit it snapped...Dohhhh Time to replace the FPR housing!!..How hard is this to replace? The connector that goes into the housing also broke off into the brass nut...arghghg Anyone have any good advice on kits or how to re-flare the tip of the fuel line while it is in place?
Thanks all!
Semper Fi
Samuel Adams
Usmc1968 is offline
post #9 of 19 (permalink) Old 02-14-2016, 04:33 PM Thread Starter
Usmc1968's Avatar
Ok, so I received all the O rings from Bob at Diesel O rings, cut and re-fluted the return line, rebuilt the fuel bowl with all new O rings. But now the biggest bugger is getting the old compression fitting out of the tubing nuts. I have been using pick tools but what a pain. Any hints or suggestions on getting those buggers out?
Thanks!
Semper Fidelis
Samuel Adams
Usmc1968 is offline
post #10 of 19 (permalink) Old 02-14-2016, 11:38 PM
klhansen's Avatar
My Photos: (180)
If I'm understanding correctly, you cut the line off and re-flared it, and now need to get the broken piece out of the nut. I'd suggest putting the nut in a vise and using a sharpened punch to tap the broken stub counterclockwise. Or try a screw extractor that will engage the center of the stub.
), AIS,
regulated return,
klhansen is offline
post #11 of 19 (permalink) Old 02-15-2016, 07:04 AM Thread Starter
Usmc1968's Avatar
I removed the old nut when I cut the line. What you see in the picture is the new nut and new sleeve that I installed before re-flaring. What I am referring to is if anyone has tips/suggestions on removing the old degraded compression sleeves on the remaining 3 nuts. I have been picking at them with a picking tool with little progress.
Thanks!
Semper Fidelis
Samuel Adams
Usmc1968 is offline
post #12 of 19 (permalink) Old 02-16-2016, 05:57 AM Thread Starter
Usmc1968's Avatar
Ok, so it also looks like I need new Alternator. Does anyone have any experience with Bosch? Specifically this one AL7555N, it only cranks out 105 AMPS is that enough? I have the Camper package on my 2000 F250 SD, 7.3. I have gone over all kinds of posts on alternators but no reference to Bosch and to stay away from re-manufactured ones (most brands)
Semper Fidelis
Samuel Adams
Usmc1968 is offline
post #13 of 19 (permalink) Old 02-16-2016, 02:57 PM
crashz's Avatar
105 seems a little light. But if you don't plow snow or used very heavy electrical devices, maybe. Bosch seems like the German Samsung. Makes everything. Some great, some good. I've never witnessed a Bosch (or Samsung) piece of junk. Still seems like you might want more amps though.
2003 F450 C&C Dump Truck, 7.3L PS Diesel, 2wd, ZF6 - 166K miles
Mods: Superchips 1705 Mini Tuner- Tow Safe Tune, HPX oil crossover.
Mods to be finished: - Glow Shift Gauges (Boost, EGT, Fuel Pressure), International Up-Pipes, Turbo seals, pedestal and EBPV delete. Hutch mod
crashz is offline
post #14 of 19 (permalink) Old 03-31-2016, 05:04 AM Thread Starter
Usmc1968's Avatar
Well folks, after replacing the FPR housing,fuel line pressure sleeves, and fuel bowl O-rings I have no more leaks! The engine valley has been bone dry for over a month of driving!! Thanks all for your help.
Semper Fidelis
Samuel Adams
Usmc1968 is offline
post #15 of 19 (permalink) Old 03-31-2016, 06:09 AM
ArcticDriver's Avatar
Semper Fidelis
Thanks for following up.
I have my fuel bowl o-ring kit from Diesel O-Rings but have not started the project yet.
Did you do the complete disassembly and cleaning of the fuelbowl found on the Guzzle website?
Also, I didn't buy the new FPR housing...is that typically replaced at this same time?
NOS Black CPS. ScanGauge-II. Bilstein 5100. Stancor GPR. Walker BTM. Noco Mod. Michelin Defender LTX 285/75/16.
SOLD:
ArcticDriver is offline
