Need help. put batteries back in. - Diesel Forum - TheDieselStop.com
post #1 of 2 (permalink) Old 12-23-2013, 03:27 PM Thread Starter
Tazzman's Avatar
Thought I had a battery problem took out had charged, found to be starter fixed that. Hooked batteries back up, turn key truck started like it should.
Now I have no door charms when door is open and keys in, radio has to be powered on and off manually doesn't shut off when door is open, my inside dome light doesn't come on when door is open.
My power door locks dont work at all. I can list more, stuff does work just not the way they did before I disconnected the batteries.
I did check all the fusees under the driver side. all where good. Not sure if any more fusees anywhere else
02 F250 Super Duty 7.3
Truck runs good, power windows work and AC/ Heater and all that.
Just dont know where else to look or where to start to look.
Tazzman is offline
post #2 of 2 (permalink) Old 12-23-2013, 06:32 PM Thread Starter
Tazzman's Avatar
Just adding, with keys in hand, Power windows and radio work when they should not be working.
02 F250 4x4 7.3 / 3.73 gear stocked Crew Cab Long bed.(306,650 miles on her) SP diesel exhaust brake and TC lock - not using the TC lock.
Riffraff:
FRx and HPx installed whit 306,550 miles.
1993 F350 7.3 IDI Ex cab dually long bed(Sold)
Tazzman is offline
