No Air out of Vents - Diesel Forum - TheDieselStop.com
post #1 of 2 (permalink) Old 05-17-2018, 03:42 PM Thread Starter
No Air out of Vents
If my truck has been sitting and I turn on the AC to max, there is a delay. I can hear it blowing but nothing out of the vents at first. After several seconds it will blow as normal. I'm assuming that I have a vacuum leak. Is this a hose issue or reservoir?
HoustonStroker is offline
post #2 of 2 (permalink) Old 05-17-2018, 05:17 PM
RT
RT's Avatar
Almost always, it is a hose issue. Do you have 4x4 hubs? If so, it could also be a leak there.
RT is online now
