No A/C '2003 F250 - Page 2 - Diesel Forum - TheDieselStop.com
post #16 of 24 (permalink) Old 05-13-2018, 05:54 PM
444-4D's Avatar
Originally Posted by fordtough79 View Post
...... I'm thinking the dryer might be bad?
I once had a guy tell me he thought his car wouldn't move because the u-joints were slipping.
444-4D is offline
post #17 of 24 (permalink) Old 05-13-2018, 06:08 PM Thread Starter
Sorry...not a pro here. Trying to learn, that's why I posted the thread. Give a guy a break. We are all not pro mechanics.
fordtough79 is offline
post #18 of 24 (permalink) Old 05-13-2018, 06:44 PM
RT
RT's Avatar
No - the dryer doesn't really "go bad" - the dessicant can disperse throughout the system, but that is rare. More likely you are still either undercharged or you have a restriction in the orifice tube. Really need high and low side pressures to evaluate this, with respect to ambient temperature and cabin temperature.
RT is online now
post #19 of 24 (permalink) Old 05-13-2018, 06:44 PM
RT
RT's Avatar
Did you sell him some anti-slip additive?
RT is online now
post #20 of 24 (permalink) Old 05-13-2018, 06:50 PM Thread Starter
Hey RT,
Thanks for the reply. I didn't have access to any other gauges other than what came with the can, so was not able to get high side pressure. The temp inside the truck had to be over 100 degrees (sitting in the sun all day) and outside temperature was around 75. Took it to the shop on Thursday to have it and other issues checked out.
post #21 of 24 (permalink) Old 05-13-2018, 07:27 PM
444-4D's Avatar
I got to rebuild his transmission, an early 60's T-Bird.
The owner of the shop had a little fun out of the guy, he took it well.
He was the Doctor we all went to if we needed a Doctor.
444-4D is offline
post #22 of 24 (permalink) Old 05-13-2018, 07:31 PM
RT
RT's Avatar
You’d have to be a doctor to afford to keep one of those old Tbirds running...
RT is online now
post #23 of 24 (permalink) Old 05-13-2018, 07:36 PM
Domenic's Avatar
Hey folks!
Thanks for all your replies. I bought an extended warranty, and it looks like the system might be covered. The dryer is not getting cold at all, can't see any oily substances, so at this juncture I'm thinking the dryer might be bad?
The A/C is low on refrigerant, has a leak somewhere. Shouldn't be hard to find by the shop.
Good deal having insurance, should be back to normal soon.
Here in California we have to leave a deposit of $5 per can of 134 as a recycling deposit. 30-days to recover the $5 per can.
I stocked up while at the Idaho ranch!
2003 F250 SBSC 4X4 7.3 6spd..Great Truck!!
2004 Jeep Wrangler Unlimited built for the rocks
Domenic is offline
post #24 of 24 (permalink) Old 05-14-2018, 10:49 AM
Hey fordtough, sounds like your short on equipment to properly fix the a/c... it’s best to have a shop put some dye in the system and watch for leaks, fix the leaks and add the proper amount measured by weight. I know it sounds long and expensive but it’s the only way to properly fix it. “Decadents” or “air dryers” only go bad if the system is exposed to air (leaking system could do it if the leak is bad) please remember that r134 is still toxic to our environment, it’s just not as bad as r12
FUMMINS MAN
C.MITCHELL is offline
