Not a good morning. Emergency brake didnt hold - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By bugman
post #1 of 5 (permalink) Old 12-16-2018, 11:40 AM Thread Starter
Most folk know that I really fancy this truck and often toot its horn when it comes to how good of shape the truck is in. This morning I experienced my first major blemish.
Pull the truck out of the garage and set the brake, went back to get the trash and was on my third trip when I turned around to see the truck was drifting down through the yard. I took off like a bat out of torment but didnt catch it in time before it side swiped the clothes line pole where several bird feeders were hanging. Fortunately I was able to catch it before it hit a maple tree head-on but my drivers side door is history. The mirror pulled the top of the door down and there is a large gap not allowing it to seal. What a bummer!
2001 Lariat, F250, 7.3, 6-speed, 3:73, Ford AIS, MBRP 4" turbo back, ATS ported housing, 205° t-stat, Infinity DX w/DP Tuner 80hp tow, coolant filter, Hutched & Harpooned, EGT & Boost gauge. Fuel Mavericks with 285/18, 86k miles(Jan-2017) Bought brand new April 2001.
aclasshog is offline
post #2 of 5 (permalink) Old 12-16-2018, 02:34 PM
not a good morning saids it all
early 99 f250 auto 190000 miles ts6 chip, riffraff frx, 6637 filter with riffraff cover edpv delete 4in exhaust tru- cool max,dedc tow mirrors with lights/heat,glow shift boost,egt,trans, fuel, gauges. hopkins agility brake control,pyle backup camera,firestone air bags,marinco plug, 265/75r 16 cooper discoverer a/t3 tires sinister diesel coolant filter,Bilstein 5100 stancor gpr.
stumpman is offline
post #3 of 5 (permalink) Old 12-17-2018, 11:32 AM
BS Hauler's Avatar
I have a 02 with the manual trans. I really wish these trucks had a lot better parking brakes. Mine will not hold itself on a slope. And yes i have went thru them a couple times and it just seems like you can't put enough pressure on them to get them to hold. I am thinking about putting a micro lock on mine. I had one on my older truck when we had a cattle trailer on it. You could leave the brakes locked for a week and you couldn't even drive thru them.
02 F350 Lariet CCLB 4wd Dually 7.3 6sp M. 122,000 miles, Manual hubs and transfer case.
Stock as of yet. So far have bought
4" MBRA turbo back with muffler
GTP 38R BB turbo and WWII wheel and high flow housing, Non EBV pedestal, Adrenaline HPOP.
New IH up-pipes, Aluminum intake plenums, 203* Therm with aluminum housing, Boost relief valve, all new boots, FPRx and HPRx. Coolant and Trans Filter kits. Max AC Assist control Valve. 8 gauges,
Boost,Pyro,Fuel,HPOP,LPOP pressure. Water,Oil and Trans Temp. Need tunes and injectors yet.
03 26' CM 4 Horse trailer and 25' GN flat bed.
06 F-350 Lariet CCSB SRW 4wd Auto 6.0 78,000
miles. Atlas 80 with Ed's lifetime, Blue spring, MBRP 4" turbo back with muffler, Bully Dog for monitoring. So far no problems.
BS Hauler is offline
post #4 of 5 (permalink) Old 12-17-2018, 01:01 PM Thread Starter
I learned a painful and valuable lesson yesterday BS Hauler.
i've been noticing the need to push the EB harder to get it to hold but I still dont understand why the darn thing sit there for 2 minutes before deciding the run off. I'll definitely be keeping a chock with me from now on.
post #5 of 5 (permalink) Old 12-17-2018, 03:30 PM
bugman's Avatar
My Photos: (12)
It was locked in just enough to hold the truck as you got out. Then with the truck running causing vibrations it slowly lost grip until the truck was moving. Having to push the brake down harder and harder could of been a indication that there was a problem with the e-brake actually making enough contact to actually hold the truck.
aclasshog likes this.
bugman is offline
