Only start in neutral - Diesel Forum - TheDieselStop.com
post #1 of 2 (permalink) Old 05-18-2018, 02:21 PM Thread Starter
User Name's Avatar
00 Super Duty with Automatic sometimes the truck will not go into "Park" and actually engage the lock sometimes unless you let the truck roll while holding the lever as high up as you can on the column and sometimes it wont start unless the truck is in "Neutral". I dont know if there is a switch that controls either function or if a linkage is simply not adjusted properly.
Does anyone have any answers for me and what I should be looking for ?
User Name is offline
post #2 of 2 (permalink) Old 05-18-2018, 03:00 PM
jleedog's Avatar
Not sure if this is your problem, but its worth checking the bolt under the dash.
2002 F250 Super Duty Crew Cab 7.3L Lariat 2WD 131,000mi; 4in turbo back custom exhaust, Garrett GTP38R turbo, Riffraff intercooler boots, Dorman Up-Pipes, Ford Severe Duty AIS, 31 row 6.0 transmission cooler, Scangauge II, ISSPRO EV2 Boost-EGT-Trans temp-Fuel pressure Gauges, DP T-5 Tuner (stock ,60HP tow, Decel, 60HP highway econo, 80HP city econo), Dieselsite coolant filtration, Max Air A/C mod, foglight mod, AIH delete, LED interior, back up camera, hid foglights.
I have AE if you are in San Diego area and need help. Send PM
jleedog is offline
