Overhead Computer Fix - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By 53fordguy
post #1 of 9 (permalink) Old 07-09-2013, 12:49 PM Thread Starter
Originally Posted by 2000F250-7.3 View Post
The link you give leads to nothing hoping you might have a new link you can share.
thanks mike
I would suggest soldering the chips rather than just pressing them back in place. Otherwise, just search of "overhead console repair" or something similar to that. It is a fairly common problem, so there are quite a few how-to fixes.
Biomettom likes this.
2000 F350 lariat, crew cab, long bed, 4x4, 3.73 limited slip
LASB turbo from Irate Diesel
Bellowed up-pipes
4" turbo back exhaust
Gauges (EGT, Trans Temp, Boost)
AFE Stage 2 XP Pro Guard 7
DP Tuner F6 (no start, stock, 80e, 60e, 60t)
AIH delete and CCV mod
F650 Dash with Carling switches
2002 Headlights with FX-R HID bi-xenon projector retrofit and 50W 5000K bulbs
53fordguy is offline
post #2 of 9 (permalink) Old 06-14-2014, 08:31 AM
Thumbs up Display Fix
Good one thanks much !!!!!!!!!!
indian347 is offline
post #3 of 9 (permalink) Old 11-23-2014, 11:27 PM
Awesome DIY!
thzpcs is offline
post #4 of 9 (permalink) Old 04-03-2017, 04:29 PM
Catch-All's Avatar
excellent video. top notch. Top Notch!
I'm the second owner of my truck and from Day One the damn overhead console display has never worked and I was too damn cheap to get it fixed cuz I reckoned some dealership or repair garage would ding me for several hundred bucks.
This video's step by step instructions and advice makes it easy enough for even a knucklehead like me to attempt the repair! THANK YOU!
Catch
2000 F-250 Lariat crew-cab. Bought used in early 2007 at 140k miles, now it's a little over 200k. Basic chip job via SuperTuner at Towing setting. Air Raid air filter. DieselSite thermostat and new housing. Dents repaired and Repainted white by MAACO. Aftermarket LED lights for pickup bed brake light and tail lights. Aftermarket headlights - CCFL halo lights. New fuel/water sep drain valve. New starter motor. New Glow Plug Relay. New alternator & serp belt. New tires all around (NEVER buy Uniroyal or Michelin - they're all junk and they don't honor their warranty). Repaired transmission housing & brake lines that WalMart dinged up during an oil & filter change. Truxedo roll-up tonneau cover. New upper & lower ball joints at 206k miles. New steering box. New tailgate. NEXT PROJECTS: DIY truckbed rust removal & heavy-duty coating, de-water fuel tank.
Catch-All is offline
post #5 of 9 (permalink) Old 04-04-2017, 09:19 PM
Catch-All's Avatar
unfuxated
My overhead console is working! Only 15 mins at lunchtime out in the parking lot and bingo, Jed's a millionaire.
The only question I have is about the fuel mpg feature. It has a constant of 14.3 mpg. It doesn't vary no matter how hard or easygoing I drive it. Is the readout an average of the fuel burned vs the mileage driven or is it an ongoing readout based on that moment's driving?
Thanks again!
Catch
post #6 of 9 (permalink) Old 05-05-2017, 01:14 PM
Catch-All's Avatar
Thumbs down
Dangit. The damn thing went dark on me again....
Reckon I'll have to fix it again and maybe use snot or something to make sure the dang chips stay seated.
post #7 of 9 (permalink) Old 02-07-2018, 03:48 PM
gdp
Soldering circuit boards usually doesn't turn out well for me. Instead of soldering the chips back in, I took some Elmers glue, smeared a little on the chip and stuck em in. That was over a year ago and still works.
2002 F-250 CC Lariat 7.3 diesel, 170,000 miles
gdp is offline
post #8 of 9 (permalink) Old 02-08-2018, 11:23 PM
Just bought a newer 99 power stroke with display not working. Looks to be easy fix. Thanks
Randy 4614 is offline
post #9 of 9 (permalink) Old 01-06-2019, 08:32 AM
JakeSpoon's Avatar
I opened mine up and one of the "chips" was MISSING!!!
ended up going to a UPULLANDPAY junk yard (on half price day at that...) found an excursion that had overhead computer - of course it does not fit- why would it be that easy.
I did however pull/melt out the chip i needed and soldiered in place on my unit, put back together, crossed fingers and turn the key forward and WHAAAA-LAAA. . . It works cost me a grand total of 2.50 !!!
thanks to all for the info
1999.5 F250 CC 4X4 PSD Lariat White over Gold BONE STOCK w/ 205475 miles as of 1-1-19
JakeSpoon is offline
