Overhead console "miles to empty" way off - Diesel Forum - TheDieselStop.com
post #1 of 12 (permalink) Old 09-08-2006, 10:56 PM Thread Starter
My outside temp and MPG read fine. I can fill the tank and it will say 175 miles to empty. Any ideas?
2002 F350 4x4
PPrash is offline
post #2 of 12 (permalink) Old 09-08-2006, 11:03 PM
NEVRNF's Avatar
Re: Overhead console "miles to empty" way off
Are you reseting the overhead when you fill up?
Tony
01 F350 cc 7.3 with Lots of Xtras
99 F250 xcab 7.3
91 mustang 351 turbo roadracer
NEVRNF is offline
post #3 of 12 (permalink) Old 09-08-2006, 11:17 PM Thread Starter
My Excursion never needs reset. I assume it takes the fuel level input and calculates off the average MPG?
2002 F350 4x4
PPrash is offline
post #4 of 12 (permalink) Old 09-09-2006, 07:43 AM
NCHornet's Avatar
Mine did this once after doing some steep off roading while retreaving a nice 8 pointer. The tank was below 1/4 and it took about 20 miles after filling up for the MTE to read correctly. Is your gauge reading correctly.
NCH
2000 Ford F350 4X4 Auto,Crew Cab Lariat, Western Hauler Package, Long bed,
Isspro EV Guages on A-Pillar, Coolant change from Green to Gold to Red,
SCT XCalibrator2 with DP's 60 tow,80 econo,120 Race
Fumoto Valve, Marinco Mod, Homemade CCV MOD,Fuel Neck Mod, KMC Wheels at all 4's
Monroe Reflex Shoxs, SS/Kevlar Brake Lines,
FTVB from Greg Evans,Ford AIS Intake
Coolant filter,Walker BTM, Attwood Gooseneck ball flush mount,6.0 cooler, 2002 headlights & corners
Zoodad Mod,Cyro'd Powerslots and Hawks LTS Pads. 2005 front grill
Turbo Lifesaver, Infinity Refrence x4, powered by Infinity Reference amp, sounds awesome!!
Towing a 2005 HORNET 30BHSS 8500 LBS,
Stopping it with a Prodigy P3 Controller
Friends Don't Let Friends Drive Trucks With Generic Tunes!!
NCHornet is offline
post #5 of 12 (permalink) Old 09-09-2006, 10:10 PM Thread Starter
I tried today to reset it and you cannot reset the MTE. You can reset the average MPG. Does anyone know what "module" or where the computer is that takes these inputs to display this info? I will swap from my Excursion and see if the issue moves.
2002 F350 4x4
PPrash is offline
post #6 of 12 (permalink) Old 09-10-2006, 05:40 AM
NCHornet's Avatar
I thought it read it from the float so is your gauge on the dash reading correctly? Take a rubber mallet and hit the sides of your tank. Some that have had the float stick after a fill up have fixed it by doing this.
NCH
NCHornet is offline
post #7 of 12 (permalink) Old 09-10-2006, 07:42 AM Thread Starter
Dask gauge is perfect.
2002 F350 4x4
PPrash is offline
post #8 of 12 (permalink) Old 09-10-2006, 08:06 AM
JimTJr's Avatar
My Photos: (20)
Do you shut off the truck while you fill it up? Mine would act screwy for a while if I didnt do that on my 99.... (Dash gauge would take longer to come up.. but computer would act screwy for longer,,) Just a thought.
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB.
New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
post #9 of 12 (permalink) Old 09-10-2006, 01:42 PM Thread Starter
yes, and it is that way with a full tank after 5-7 shut downs. Always seems to say around 170 MTE.
2002 F350 4x4
PPrash is offline
post #10 of 12 (permalink) Old 09-11-2006, 05:46 AM
NCHornet's Avatar
Unplug both batteries over night and it should reset itself.
NCH
NCHornet is offline
post #11 of 12 (permalink) Old 09-11-2006, 08:53 AM
NEVRNF's Avatar
Or just drop the console and unplug the display.
Tony
99 F250 xcab 7.3
NEVRNF is offline
post #12 of 12 (permalink) Old 09-09-2019, 01:52 PM
Ever figure this out? Mine has the same issue but it was after I had replaced the overhead console computer. Was wondering if there is some configuration that needs to be done or whether there is another sensor that sends the info that went bad while my original OH console computer was down.
davidlgreencpa is offline
