pickup bed - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 04-22-2019, 05:10 PM Thread Starter
divenride's Avatar
pickup bed
Will a bed from 2019 pickup fit on a 2002 pickup?
2015 Larait, F350, CC, 4x4, SRW, AmsOil Bypass filter, BD3 Trail Saver 5th Wheel Hitch, Bilstein 5100's, DieselSite fuel filter/with water separator,
divenride is offline
post #2 of 3 (permalink) Old 04-23-2019, 07:49 PM
Big Horn's Avatar
According to this write up, only up to a 2016 will fit. I have copied the article for you:
https://www.expertswrite.net/tech/te...d-removal.html
2002 F350 7.3L / 4R100 - 4WD CC DRW 8 Box, AIH Delete, Gauges- Pyro, Trans Temp, Boost, Fuel Pressure, TS-6 tuner, Zoodad Mod, Mishimoto 31 row Trans cooler, Mobil 1 ATF, Trans return line ATF filter, Hutch/Harpoon Mod, Air Lift Load Lifter 5000 rear air springs, Rancho 9000 shocks, Timbrens on the front.
Big Horn is offline
post #3 of 3 (permalink) Old 04-24-2019, 03:18 PM Thread Starter
divenride's Avatar
Thank You, Big Horn
Similar Threads
2015 cab chassis questions bakerranch '11-16 Ordering Information 15 09-29-2016 11:28 AM
Got rid of my hauler bed Strokin' 6.0 1999-2007 Upgrades and Aftermarket - General 6 09-17-2012 09:45 AM
How do you haul longer items in a short bed pickup? larry_minn Towing and Hauling 8 05-24-2007 10:00 AM
92 bed on 86 ldw 6.9L IDI Diesels (Not Power Strokes) 1 05-04-2005 09:29 AM
