Rim size - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 08-19-2019, 01:00 PM Thread Starter
Send a message via AIM to labill Send a message via Skype™ to labill
Rim size
The rim on my 2004 F250 Super Duty, 16 inch, 8 lug is bad and I need to replace.
On line, rims show 8 and 10 inches. Not sure what I need. It is stock and SRW.
Thanks,
labill
labill is offline
post #2 of 4 (permalink) Old 08-19-2019, 08:22 PM
I'm thinking its probably 8", but I'd measure it to be sure.
DonWarkentin is offline
post #3 of 4 (permalink) Old 08-19-2019, 08:48 PM
bugman's Avatar
My Photos: (12)
It should be stamped on the rim if they are steel. Not sure if they are aluminum, perhaps look on the brake side of the rim.
But I am betting they are 8" or 203mm
bugman is online now
post #4 of 4 (permalink) Old 08-19-2019, 10:06 PM
klhansen's Avatar
My Photos: (180)
Stock size would have been 16x7. Stock tire sizes were 235/85R16 or 265/75R16.
I believe it was in 05 with the front suspension change that the wheel offset was changed.
Size was also stamped on the interior of the rim on alloy wheels.
), AIS,
regulated return,
klhansen is offline
