tack not working - Diesel Forum - TheDieselStop.com
post #1 of 12 (permalink) Old 12-28-2018, 02:15 PM Thread Starter
tack not working
hi everyone I'm new to this forum I have a 2002 f 250 with 7.3 automatic I have lost the tack, trans temp the glow plug light stays on and the check gage light stays on I did a gage test and the gages responded but when you put the key in and stat the truck the tack docent move and swapt the cluster for an new one and same problem occurs I'm sorry if this is in the wrong place I'm new to this forum
zdetlor0923 is offline
post #2 of 12 (permalink) Old 12-28-2018, 02:20 PM
ArcticDriver's Avatar
So your tach did not work at all and you installed a new cluster and the tach still does not work at all? The needle does not move?
But the truck starts and runs fine?
SOLD:
ArcticDriver is offline
post #3 of 12 (permalink) Old 12-28-2018, 02:21 PM Thread Starter
correct
post #4 of 12 (permalink) Old 12-28-2018, 02:23 PM
You posted a few months ago about doing a 2010 conversion into a 2002 including the dash.
Did your problems start after this conversion?
https://www.thedieselstop.com/forums.../652374?page=1
SOLD:
post #5 of 12 (permalink) Old 12-28-2018, 02:26 PM Thread Starter
the past few days it has bin acting up power loss for split seconds when on the throttle
post #6 of 12 (permalink) Old 12-28-2018, 02:27 PM Thread Starter
no it was happening before that
post #7 of 12 (permalink) Old 12-28-2018, 02:35 PM
Did you complete the swap? Is the dash and cluster you now have installed from a 2002 or 2010?
SOLD:
post #8 of 12 (permalink) Old 12-28-2018, 02:43 PM Thread Starter
No the 2002 cluster is still in because I wanted to fix the issue befor I started messing with swapping the cluster I am currently building one but haven’t messed with because I don’t want to add more problems
post #9 of 12 (permalink) Old 12-28-2018, 02:56 PM
OK.
Good details.
SOLD:
post #10 of 12 (permalink) Old 01-07-2019, 06:13 AM Thread Starter
Any ideas?
post #11 of 12 (permalink) Old 01-16-2019, 08:27 PM
Calico5's Avatar
On the 2002's, the tach is controlled by the instrument cluster, and the cluster receives the engine-speed information (RPM) from the PCM via "SCP" communications.
In the older trucks (up to 2000-ish) the tach was directly "driven" by a pulse-signal output from the PCM (a CPS "reflected" signal).
I don't have my manuals for the '02 here at home tonight. I'll read up tomorrow at work and report back...
~Al
Al in SoCal
AFE Intake; Garrett 38R; DieselSite Turbine Jacket
HPS Hi-Temp CAC Boots; Banks Big IC, Banks Engine Brake
External Oil cooler & Remote filter; Stealth 4-line Twin HPOP, Melling LPOP
Swamp's: 160cc/30% Injectors & HVHF IDM; DP-Tuner F5; Fluidamper Balancer
Custom Full Reg.-return Fuel System, Pre-& Post-pump filtration
Mishimoto Radiator & Exp. Tank; T444 Water Pump w/Filtration
Bellowed S/S Up-pipes; 4" Turbo-back Custom Exhaust into Twin Stacks
SouthBend D-D Clutch; ZF 6-spd w/CoreShifters Short-throw Stick
GearVendors O/U Drive
Calico5 is offline
post #12 of 12 (permalink) Old 01-17-2019, 03:10 PM Thread Starter
Thank you I would really appreciate it
