Trac arm mount - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 07-17-2019, 06:13 PM Thread Starter
Whiskyb's Avatar
Trac arm mount
Had a noise under my 01 the other day. Crawled under and found on the passenger side where the trac arm mounts at the lower spring perch had rotted away. It is welded to the axle and I have not found any suppliers of them. Would adding a leveling kit have put more load on it. My jeep has a adjustable trac arm. Do they make one for our super dutys? Not having much luck finding replacement parts.
Whiskyb
2001 F350 4X4 Super Duty PSD Dually
Almost 400k and still given her
DP Tuner
and guages, DIY air intake, BTM,
Dieselsites trans and coolant filters
Wicked wheel 2 (Gone) , Guzzles billet fpr
Whiskyb is offline
post #2 of 4 (permalink) Old 07-17-2019, 11:16 PM
klhansen's Avatar
My Photos: (180)
I think that you'll have to try and find a wreck to get that spring perch and track bar mount from. Either that or have a welder fab something up to fix it. I think that there probably are adjustable track bars available, but I've never tried to track one down.
), AIS,
regulated return,
klhansen is offline
post #3 of 4 (permalink) Old 07-18-2019, 06:40 AM Thread Starter
Whiskyb's Avatar
Welded it up, will keeep looking though. Thanks
Whiskyb
DP Tuner
Whiskyb is offline
post #4 of 4 (permalink) Old 08-07-2019, 06:27 PM
Responded to wrong thread
2002 F250 XLT 4WD SC SB with 6 Speed and Manual Shift Transfer Case. Pillar pod-o-gauges, Warn Premium Hubs, AIS, Fumoto, Edge 3 leveling kit on the front (with adjustable track bar), 4 blocks on the rear, Eaton Posi, Bilstein 5100s and 285 X 75 X 16 BFG MTs all around. Oil pan coated with POR-15. Fleetrite ELC and Dieselsite coolant filter (plus new water pump). New O-Rings on the injectors.
Shamish is offline
