Video for pulling dash? - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By klhansen
post #1 of 6 (permalink) Old 11-12-2019, 12:58 PM Thread Starter
kench's Avatar
Anyone have a good video link to pulling the dash and gauge cluster to replace some bulbs?
2001 F-350, 7.3L, Crew Cab, 4x4, Dually.
202,000 miles, and going strong.
4" Turbo Back MBPR Exhaust
S&B Cold Air Intake
DP-Tuner F5 Chip
6.0 Trans Cooler
It likes to pull a 44' 3" 2016 XLR Thunderbolt 420AMP Toy Hauler
ISSPRO 3 gauge (pyro, boost, trans) pillar install.
Located on Long Island, NY
kench is offline
post #2 of 6 (permalink) Old 11-13-2019, 06:33 PM
klhansen's Avatar
My Photos: (180)
Don't have a video, but it's not that hard. Pull the radio out with the u-shaped radio removal tools. Available at most any parts store or Wally World. Stick them in the holes at the side till they click, then pull the ends away from each other and pull the radio out. The remove the two hex head screws at the top of the radio opening. After that, just grab the dash panel and tug. The headlight switch comes out with the dash panel, so you'll need to pull the wiring connectors loose to fully remove the dash. The instrument cluster comes out with 4 (IIRC) screws.
kench likes this.
), AIS,
regulated return,
klhansen is offline
post #3 of 6 (permalink) Old 11-14-2019, 09:18 AM
jleedog's Avatar
Found this online, hope it helps!
2002 F250 Super Duty Crew Cab 7.3L Lariat 2WD 131,000mi; 4in turbo back custom exhaust, Garrett GTP38R turbo, Riffraff intercooler boots, Dorman Up-Pipes, Ford Severe Duty AIS, 31 row 6.0 transmission cooler, Scangauge II, ISSPRO EV2 Boost-EGT-Trans temp-Fuel pressure Gauges, DP T-5 Tuner (stock ,60HP tow, Decel, 60HP highway econo, 80HP city econo), Dieselsite coolant filtration, Max Air A/C mod, foglight mod, AIH delete, LED interior, back up camera, hid foglights.
I have AE if you are in San Diego area and need help. Send PM
jleedog is offline
post #4 of 6 (permalink) Old 11-14-2019, 02:06 PM
klhansen's Avatar
My Photos: (180)
Yeah, that'll work.
), AIS,
regulated return,
klhansen is offline
post #5 of 6 (permalink) Old 11-21-2019, 08:12 AM Thread Starter
kench's Avatar
Pulled that dash and changed the burnt bulbs.
Not a hard job at all.
I have an aftermarket radio, and couldn't for the life of me figure out how to get it out, so I left it attached to the dash. It would have been easier without the radio in, but it is certainly doable.
Hardest part was getting the gear indicator back in the slot using my fat hands!
Oh, and paying $6 for two of the tiny #37 bulbs was hard too!
I got a pack of 10 of the bigger bulbs on amazon for like $4!
S&B Cold Air Intake
DP-Tuner F5 Chip
6.0 Trans Cooler
kench is offline
post #6 of 6 (permalink) Old 11-21-2019, 08:18 AM Thread Starter
kench's Avatar
Although I did notice it looks like I'm missing a bulb assembly in the "brake" slot.
I never use the e-brake, so I never noticed the brake light didn't come on.
S&B Cold Air Intake
DP-Tuner F5 Chip
6.0 Trans Cooler
kench is offline
