Weatherstrip for the Supercab - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By DownEastDiesel
post #1 of 4 (permalink) Old 01-20-2018, 10:59 AM Thread Starter
Andrew G's Avatar
Does anyone know of a good source for the door seals for the supercabs? I've found listings for the front door seals, but nothing for the backwards half doors. I tried doing the weatherstrip mod, but the seal tore halfway through, and now is leaking water into the cab. If I could find a set, I'd just like to replace them all...
99.5 F250 7.3 PSD Supercab Shortbed 4x4 on 315 75 16s
Front leveling springs, Hutch and Harpoon mods, A pillar 3 gauge pod with DiPricol Trans, Boost and EGT, Scangauge II, CNC Fab HPOP and HPX lines, Riffraff FRX, 2004 Heated and Lighted mirrors
Andrew G is offline
post #2 of 4 (permalink) Old 01-25-2018, 02:04 PM
My Photos: (5)
I replaced mine recently. Purchased through Tousley Ford which is now known as AutoNation Ford White Bear Lake. 651-484-8888 Complete set was about $270 + shpg
6.0L, F-250 XLT, Torqueshift, S/C, L/B, FX4, 3.73
Truck Build Date: 02/05/05 Kentucky
Engine Build Date: 02/03/05 Indianapolis
Gone but not forgotten - '99 7.3L F-250 XLT S/C, L/B
DownEastDiesel is offline
post #3 of 4 (permalink) Old 01-25-2018, 08:41 PM Thread Starter
Andrew G's Avatar
That might be what I have to do as well. Thanks for the info. Do you have any part numbers from your purchase?
Andrew G is offline
post #4 of 4 (permalink) Old 01-28-2018, 11:22 AM
My Photos: (5)
Apologies, I misplaced the invoice. They will most likely ask you for the last 8#'s of the VIN to get you the correct parts. Probably best anyway to call and talk to them.
ArcticDriver likes this.
