Weird door ajar light problem - Page 11 - Diesel Forum - TheDieselStop.com
 3Likes
post #151 of 166 (permalink) Old 01-07-2016, 01:11 AM
Originally Posted by yan7gin View Post
Try pulling the fuse 19 and 102, whait a couple hours and put them back.
Worked for me.
Sent from AutoGuide.com Free App
Doubtful this will do anything since both my batteries were disconnected and removed for about 3 days a couple days ago while I was doing turbo work and replacing the up pipes. But I'll give it a shot for the hell of it.
From the looks of it, it may be the instrument cluster itself that's bad. Too bad there's not a how-to for that.
Wrench_95 is offline
post #152 of 166 (permalink) Old 01-07-2016, 11:46 AM
yan7gin's Avatar
My vsm problem started 1yrs and 1/2 ago. I had the battery disconnected multiple time for engine work and one time over 3 weeks. Back in October i removed the fuse 19 because the door keep locking and unlocking by themselves when driving or parked. 3 days ago i saw a post saying to remove the fuse 102 and 19 and it might fix it. So I removed the 102 fuse for couple hours and put both back in and everything work now.
Is ford wasn't able to connect to your new vsm or if they dis programme it and nothing change?
For what i know,
Door adjar switch (witch you did),
Vsm,
Cluster.
This is the sequence i know
Hope the fuse will help you, if not i think your next step is the cluster
F350 2002 7.3
auto, 37/13.5/20 open country, Bushwaker cut-out flare, Bilstein 5100, Maxtow gauges (EGT, Trans temp, Boost), 4 inch diamond eye turbo back axel drop with BTM muffler, S&B intake, RR AIH plug, billet FPR with gold spring, CNCfab Sgt 1 HPOP, CNCfab HPOP line with cross over, CNCfab 4 line fuel kit, ARP heads stud, RDP plenum reinforcing insert, complete CAC intercooler boot kit, full engine seal and gasket kit, 360* turbo rebuilt, WWII, EGPV delete, dark blue CPS, Hydra chip with SDK tunes, Polished compressor manifold, HD coolant, 203* thermostat, Transgo HD kit, Energy suspension bushing kit, front and rear diff fully rebuilt with 4:88 gear ratio, Z36 powerstop heavy hauling brake kit, headlight relay mod, Fumoto drain valve AND STICKER
F350 2008 6.4 (sold)
TT 26' Springdale 2014
7x17 enclose trailer (shop) 2012
yan7gin is offline
post #153 of 166 (permalink) Old 01-07-2016, 01:13 PM
S&S
S&S's Avatar
Hi, I was just wondering if that "door ajar" problem could be the source of my radio staying on and the battery drain???
I just got this truck and I don't know much about it.
In my buddy's gmc the power stays on after he shuts off the key, like if it was on "acc" until the door is opened then all shuts off.
Are these fords the same?
My interior light doesn't come on but the bulb might just be burnt, I'll have to check.
Just thinking about it... I don't remember ever seeing the "door ajar" light in the dash either?
'06 F-250
Extended cab 4x4
6.0 powerstroke
S&S is offline
post #154 of 166 (permalink) Old 01-07-2016, 04:35 PM
yan7gin's Avatar
Yes if there is a problem with the vsm everything will stay on when you open the door but it should still shutoff after 10 or 15 min. Unless you have a problem with your delay relay.
Normally the radio will shut off when opening the door and all light will shut with the delay circuit (if i remember right) but if you have a problem with your vsm, the light won't work like they should on auto, inside and third light will take a long time to shut and will always stay on when vehicle is running, radio won't shut when opening the door.
Like i suggest in my other post, try removing the fuse 19 and 102 first for couple hours and go from there
S&S likes this.
F350 2002 7.3
yan7gin is offline
post #155 of 166 (permalink) Old 01-07-2016, 10:12 PM
For what i know,
Vsm,
Cluster.
Removed those two fuses all night last night, nothing changed. So looks like the cluster, but I'm not paying for that, I'll sell it before I pay $500 for interior lights.
Over the 4 hours Ford spent trying to program the VSM, it works the exact same as the old one and the new one straight out of the box, no change at all.
post #156 of 166 (permalink) Old 01-07-2016, 10:30 PM
yan7gin's Avatar
Yap for what i know your next step is the cluster, i feel your pain
F350 2002 7.3
yan7gin is offline
post #157 of 166 (permalink) Old 02-20-2016, 05:48 PM
meteor56's Avatar
Thanks for the WD40 tip. The door ajar light of my '99 F250 would come on after a wet day, and go off once I was above 15 mph. Then back on again as I slowed below 15 mph. It would stay on for 15-30 minutes after shutdown. I sprayed WD40 in all four doors just after New Year's; the light hasn't come on in error since. I love it!
meteor56 is offline
post #158 of 166 (permalink) Old 09-17-2016, 03:14 PM
The two front doors the door ajar switches are in the latches...right? Does the 2 back doors on the extended cab have switches also? If so where are they?
Thanks,
Griz
Griz is offline
post #159 of 166 (permalink) Old 09-21-2016, 12:25 PM
I fixed my problem of the dome light staying on even if I locked the truck using the remote keypad. It turned out to be the intensity control knob for the dash lights. Why this would affect the dome light is beyond me. I don't have a schematic so I can't even guess why this might happen. I did not have an issue with the doors ajar indicator like some of you do...so I don't know if this would fix any of those issues.
Griz
02 F250, 4X4, 4R100, 3.73, B&M Transmission Pan, Edge CTS Digital Gage, Tymar 4" Exhaust, Tymar Intake & HPX & TS 6 Position Chip. IH Bellowed Up-Pipes, RiffRaff AIH delete plug, Riffraff FRx Kit. 6.0 Transmission Cooler. Dieselsite Coolant filter & Transmission filter & 203 Thermostat & WW2 & TurboMaster & inter-cooler boots. BD CCV filter. Driven Diesel Fuel Tank Mod & Pre-Pump Filter. John Wood's valve body.
Griz is offline
post #160 of 166 (permalink) Old 09-22-2016, 10:12 AM
Griz
All the way up there should be a 'click' which is the switch for the dome light. Just shy of the 'click' is dash light full.
Gator
2001 F-450 4x4 XL CrewCab Flatbed (Loved this truck, sold it to a friend and he says he will never sell it!)
2000 F-350 4x4 Lariat LE CrewCab Flatbed - 325k miles all stock, needs some maintenance but still going strong! (My daily driver)
1999.5 F-350 XLT CCSB - 335k all stock (now a parts truck)
2002 F250 CCSB 4x4 previous owner threw a lot of aftermarket money at it with little gain, added a TS6 w/Gearhead tunes. (Brother's daily driver)
2001 F350 CCLB - 180k all stock (Sister in laws daily driver)
2005 Ford Expedition (Wife's daily driver)
Wife is patiently waiting for the right Diesel 4x4 Ecursion to show up....
And many other non-Ford vehicles...
Gator5713 is offline
post #161 of 166 (permalink) Old 09-22-2016, 12:27 PM
I'll have to check that out. Does this turn the dome and cargo lights on? Because not only did my dome light stay on, the cargo and red door lights on the bottom of the doors were on also.
Griz is offline
post #162 of 166 (permalink) Old 09-22-2016, 03:25 PM
Yes. All one circuit.
Gator
post #163 of 166 (permalink) Old 09-23-2016, 01:13 PM
Yeah that is what I must have done was turn the intensity knob until the dome light came on and I didn't realize I had done that. I checked the knob and it does work like you said.
Thanks,
Griz
Griz is offline
post #164 of 166 (permalink) Old 09-23-2016, 06:53 PM
No worries. We all have those moments from time to time!
Gator
post #165 of 166 (permalink) Old 04-07-2018, 11:40 PM
My door ajar light and the dome light stay on whenever the key is on. 2003 F250 Super Duty Supercab 6.0 diesel. I have disconnected both door switches without success. Does my truck have a GEM, a VSM or an LCM that controls this function? Whichever one it is, where is it? Lots of misinformation out there on this issue from people who think they know but get contradicted by others who also think they know. Anyone know for certain?
rafternw is offline
