Weird door ajar light problem - Page 2 - Diesel Forum - TheDieselStop.com
 3Likes
post #16 of 166 (permalink) Old 05-24-2007, 10:16 AM
re: Weird door ajar light problem
So...since my driverside front door actuator seems to be not working...will this cause my door ajar light to illuminate. Its been on for months and it is getting pretty annoying. Any info is appreciated! Thanks guys.
Yep
2009 F150 Lariat, Crew, 4x4
Previous - 2004 F350, Crew, 4x4, 6.0l
newtodieseling is offline
post #17 of 166 (permalink) Old 05-25-2007, 07:16 AM
fredwilliamson's Avatar
Hmmmm. I changed all 4 of my door lock actuators today. {since the majority of people recomend it on here} The door open light is Still on. I unplugged all the sensors, installed jumper wires and the light is still on. I then {since i was bored and had the parts handy}I changed all 4 door open switches. Light is still on!! I lubed the heck out of the strikers with wd40...still on. Any Suggestions? Take it to ford and let them deal with it? Im Out of ideas.
2006 Ford F350 cab-chassis Lariat ZF6. 4x4, crew cab, 9' cm er body.
fredwilliamson is offline
post #18 of 166 (permalink) Old 05-26-2007, 11:08 PM
I've got an '02 F-350 crew-cab. The door ajar lights stay on while running. The power door locks don't work at all (inside or on the keyless entry).Also the radio does not turn off when I open the door. I've already sprayed the door latches with WD-40 but it didn't help. ANY SUGGESTIONS?
JHpowerstrokin02 is offline
post #19 of 166 (permalink) Old 05-27-2007, 01:42 AM
Read here.
Sorry to all the loyal 7.3 guys, but I traded my '91 7.3 in on a 2002 F250 Ex cab V10 4x4. SCT Xcalibrator2 with tunes by Powerplay Performance. 285/75/16 Toyo M/T's. Took a long time to get used to the ping-pop of a cooling catalytic converter...LOL.
'85 Bronco swapped up to a 302 4bbl from the 300 I6, NP435 4spd, NP208, 32x11.50x15 Radial RVT's, Soon to be 6.9 turbo powered.
86 F350 Cab&Chassis with a dump bed. 2wd 6.9 and 4 spd tranny. No mods to engine.
2000 Volvo 660 N14 Cummins, 500hp 1650 ft lbs, Autoshift tranny 10spd.
What part of "SHALL NOT INFRINGE" do you NOT understand?
aceohearts is offline
post #20 of 166 (permalink) Old 05-27-2007, 07:33 AM
Read here.
Thanks!!!! That VSM was my problem. I Appreciate it.
post #21 of 166 (permalink) Old 05-27-2007, 10:08 AM
EDIT
2008 F350 CC Lariat 4x4 LOADED!
2008TTCC is offline
post #22 of 166 (permalink) Old 05-27-2007, 10:26 PM
What's the price of this VSM?
post #23 of 166 (permalink) Old 06-02-2007, 04:17 AM
105 for the vsm and about 40 for the programing.
post #24 of 166 (permalink) Old 06-11-2007, 11:59 PM
Thanks once again, TDS. Just got here to post a question about fixing this exact issue. Saw the sticky at the top, and I'll be pickin' up some WD40 tomorrow.
Thanks, WD40 some of the BEST stuff ever made [img]/ubbthreads/images/graemlins/smokin.gif[/img]
1999 F350 Dualie Crew-Cab Lariet, PSD, AT, Long Bed, Tow Pkg, Isspro gauges & A-pillar mount, Zoodad, DIY TYMAR, 4" Full system, DP Chip, Bilstien Shocks.
stingerMX is offline
post #25 of 166 (permalink) Old 06-15-2007, 12:45 AM
Thanks Fred Williamson!! My local stealer-ship wants $218 + tax just for the module. Any suggestions?
post #26 of 166 (permalink) Old 06-15-2007, 03:23 AM
Im sorry, i forgot to mention that i bought it at cost through my work. Im so use to getting the wholesale prices i keep forgetting to clarify. I believe the retail price here in arizona is 178.42
Again Sorry.
post #27 of 166 (permalink) Old 06-21-2007, 01:20 PM
WD40 has been the best simple solution, tons of positive results.
yep
early 99 f350 4x4 crew cab
work in progress
southmike is offline
post #28 of 166 (permalink) Old 06-29-2007, 08:36 PM
BUT... if your vehicle does not have the V.S.M. like mine then you can do what I did. Pull the door panel off, unhook the linkage from the latch mechanism and the electrical plugs, take out the 2 screws that hold the latch in and carefully manipulate it out and w/a wrench take the switch off the mechanism and spray a generous portion of the world famous WD-40 liquid gold and work the action of this switch for about 5 minutes repeatidly spraying, then re-install the switch, the mechanism, the electrical plugs, and the linkages, make sure it works properly by shutting and opening several times w/ the key in the ignition turned on and the window down. If all is well, no chime and no door ajar light, also dome light will go out. Now you can re-install the door panel. Taa Daa.
dipper is offline
post #29 of 166 (permalink) Old 07-09-2007, 01:37 PM
dieselpwrdude's Avatar
WD40 is great stuff,Its good for electronics also.I once got my marine VHF radio wet and it stopped working.Just a matter of spraying WD40 inside the radio and it has worked fine ever since.
However WD40 makes for a lousy lubricant,especially in a outdoor situations.WD-40 is really just for Water Displacement...hence the name.
2003 XLT 250 Ford Super Duty Ext Cab. PSD 7.3 Stock.
dieselpwrdude is offline
post #30 of 166 (permalink) Old 08-01-2007, 08:23 AM
I call it the "Mystery Light".....
Mine has been doin it for about 3 years now. The dealer has replaced the involved switch 3 times and after that I just "let it eat".....Sometimes there is no light at all, even when I hit the switch on dash and other times, it'll stay on for 20 minutes to half an hour........Kinda used to the little red truck light on dash panel, gonna miss it when it finally burns out one day........
02' Silver F350 SuperCab. 7.3 Powerstroke, 6" Lift, 37" P.J. Dirt Gripz, lotta extras
69' and 74' Early Bronco's...Lifted on q-78 TSL Swampers.
97' Cherokee...6" Lift, custom rear bumper
02- VW Jetta..APR Chipped and tuned
Lil_SuperDuty is offline
