What is this? - Diesel Forum - TheDieselStop.com
 2Likes
  • 1 Post By klhansen
  • 1 Post By 2000F250-7.3
LinkBack Thread Tools
Old 03-25-2019, 03:26 PM Thread Starter
What is this?
After putting on a new belt, tensioner, idler pulley, & water pump I noticed this tucked away. Anybody know what this is and where itís supposed to be?
Hillbillyshakespeare is offline
Old 03-25-2019, 04:26 PM
klhansen's Avatar
My Photos: (180)
Looks like an intake air temp sensor. That would plug into the air filter box on the driver's side. But you're holding it on the passenger side of the engine.
What are you working on, a van or a pickup? With the alternator on the passenger's side, I'm guessing a van. Not exactly sure where the air filter box would be on a van.
), AIS,
regulated return,
klhansen is offline
Old 03-25-2019, 04:32 PM
2000F250-7.3's Avatar
From the looks of the picture itís a van. It is a air intake temp sensor should go in the side of the air filter box.
2000 F250 7.3 4inc exhaust, Ts 6 pos chip witch custom tunes, Built 4R100 w billet triple disc converter, 6.0 trans cooler and deep tans pan, CCV mod, 4 gauge pod A piller,Boost,Trans temp,EGT,fuel pressure AFE intake,RIFFRAFF Frx fuel Rail dead head fix black spring,High Flow banjo bolts,High Flow CVD Fitting, Harpoon mod,Diesel site adrenaline HPOP,AIH Plug,Plenum Reinforcing Inserts. FULL FORCE DIESEL STAGE 1.5 single shot injectors, Garrett powermax GTP38R and blank pedestal, RIFFRAFF Intercooler CAC Boots with complete clamp kit , scanegauge 2
2000F250-7.3 is online now
Old 03-25-2019, 06:39 PM Thread Starter
Yes itís a van. The previous owner has built an after intake for this, so that would explain it just dangling around.
Old 03-26-2019, 01:22 AM
Try to get it in the air stream of the intake some how
Old 03-26-2019, 05:35 PM
bugman's Avatar
My Photos: (12)
Just zip tie it up and out of the way and it'll be fine.
Mine has been hanging inside the fender now for 21 years.
bugman is online now
