Where does this 4x4 Hub O-Ring go??? - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 06-25-2019, 07:02 PM Thread Starter
Powerstroke3302's Avatar
I am fricking STUMPED!
I replaced the ball joints on the Dually... (see sig below)
When I removed the hubs this big (much bigger than the small one on the auto-lock section) O-ring was sitting in the groove where the snap ring holds the locker in on both hubs. The picture of the o-ring at the bottom of the hub is where I think it may go but I can't find anything to back that up. I have looked at all the schematics, called ford, and no one can tell me where that thing goes. I am really stumped. I don't think it goes behind the snap-ring. There are now marks on it. Can someone help me? I need to get this truck back together but don't want to have to go back in and redo all this.
Name:	2019-06-25 18.46.28.jpg
Name:	2019-06-25 18.46.03.jpg
Name:	2019-06-25 19.13.58.jpg
The Old Truck - 1996 F-250 SC 7.3 PSD, SRW, 4x4, 4:10 gears, bought new in May 96, TyMar Intake([email protected],000),Updated Turbo inlet hoses and breather assy,TrueCool 24,000 Tranny Cooler, Diamond Eye DP/Exhaust,Eviscerated Kitty,FPR Shimmed w/BB,Autometer z-series guages (boost, Tranny Temp, post turbo Pyrometer).Replaced Water pump @ 100,000.Rebuilt Tranny @ 140,000.Replaced GPR and Glowplugs at 159,000.Replaced brake vacuum pump 162,500.StanCor Heavy Duty GPR,4R100 tranny pan.Replaced starter @ 185000 miles : 225,000 miles as of Jan 2012
and
The Dually - 2004 F-350 Lariat CC LWB 6.0 PSD, DRW, FX-4 4x4, 4:10 Born 06/04 bought BRAND NEW on 10/26/04 Woo HOOOO This truck ROCKS!!! No mods yet,and it seems none NEEDED!! Replaced transmission @ 37k miles and EGR valve @ 58k miles : 92,000 miles as of Nov 2009
Powerstroke3302 is offline
post #2 of 9 (permalink) Old 06-25-2019, 08:37 PM
klhansen's Avatar
My Photos: (180)
There shouldn't be an o-ring in the groove inside the hub. It may be a swollen o-ring that came off the outside of the locking hub itself.
Go ahead and toss it in the garbage.
), AIS,
regulated return,
klhansen is offline
post #3 of 9 (permalink) Old 06-25-2019, 08:42 PM Thread Starter
It isn't a swollen o-ring. There was one in each hub and they are both in perfect shape. The o-ring that is in the lockers groove is much, much thinner in diameter and fits the groove it is in. So where did these come from....
post #4 of 9 (permalink) Old 06-25-2019, 10:12 PM
klhansen's Avatar
My Photos: (180)
Are you the original owner? If not, I'd say that some dufus put them in for who knows what reason.
), AIS,
regulated return,
klhansen is offline
post #5 of 9 (permalink) Old 06-25-2019, 10:14 PM Thread Starter
I am, bought it new.
post #6 of 9 (permalink) Old 06-25-2019, 10:19 PM
klhansen's Avatar
My Photos: (180)
OK, I wasn't implying you were a dufus, but someone must have put them there. I have never seen fat o-rings there. Maybe someone snuck into your garage and put them there.
), AIS,
regulated return,
klhansen is offline
post #7 of 9 (permalink) Old 06-25-2019, 10:29 PM Thread Starter
lol Oh, I didn't take it that way!
Mostly I am worried about NOT putting them back. I can't explain where they came from or go though.. Curiouser and curiouser!
and
post #8 of 9 (permalink) Old 06-26-2019, 07:37 AM
2000F250-7.3's Avatar
Every 7.3 I have worked on does not have the two big o rings you have pictures of on yours If they fit and donít cause problems put them back in. But they donít need to be there.
2000 F250 7.3 4inc exhaust, Ts 6 pos chip witch custom tunes, Built 4R100 w billet triple disc converter, 6.0 trans cooler and deep tans pan, CCV mod, 4 gauge pod A piller,Boost,Trans temp,EGT,fuel pressure AFE intake,RIFFRAFF Frx fuel Rail dead head fix black spring,High Flow banjo bolts,High Flow CVD Fitting, Harpoon mod,Diesel site adrenaline HPOP,AIH Plug,Plenum Reinforcing Inserts. FULL FORCE DIESEL STAGE 1.5 single shot injectors, Garrett powermax GTP38R and blank pedestal, RIFFRAFF Intercooler CAC Boots with complete clamp kit , scanegauge 2
2000F250-7.3 is offline
post #9 of 9 (permalink) Old 06-26-2019, 09:27 AM Thread Starter
This is on the '04 F-350 Dually...
I never saw these on anything on the old truck either...
and
