Whistling in the dash area - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 01-01-2014, 07:29 PM Thread Starter
Hey y'all! I am hearing a whistling in the dash when I accelerate and as soon as I left off the pedal. Sounds like vacuum but I'm not sure. Also have an issue with my heater going cold on me every few minutes. I am from Mississippi and didn't notice the heater issue down there but I brought it to North Dakota where obviously there is quite a temp change. Could the cold temps be cooling the radiator enough to send cool air from the vents until it heats back up?
Sent from AutoGuide.com App
JoshGandy80 is offline
post #2 of 3 (permalink) Old 01-01-2014, 07:33 PM Thread Starter
Oh this is an 07 F-250 6.0
post #3 of 3 (permalink) Old 01-02-2014, 08:20 AM
ritschner's Avatar
Send a message via AIM to ritschner
Whistling caused by a vacuum leak will not change during acceleration. Check the vacuum lines from the pump back to the dash, including behind the glove box, and back to the heater coolant bypass. Also double check the coolant level. If you have Auto climate control the system may be closing the bypass valve intermittently.
White 06 F350 Lariet CC 2WD DRW Tow Boss, Timbren SES, Bilsteins, Smiths Ultimate Bedliner, RK Tool Box, CondensorGuard, IntakeMod, S&B Intake, SEIC, Banks 4"TB, Accufab elbow, Edge Attitude CS, Blue Spring Mod, DCPower 185a alternator, Rebuilt FICM, STC and Standpipe update, Harpoon Mod, Coolant Filter, Glove Box Light, Hood Insulator, Rewired Mirror Heat, Seat Heater Indicator.
ritschner is offline
