Won't start - Diesel Forum - TheDieselStop.com
post #1 of 57 (permalink) Old 10-07-2018, 07:46 PM Thread Starter
Won't start
2003 7.3 CCSB 4x4. Recently I was maneuvering in my driveway and it died. When I went to restart, it turned slowly and didn't start. So I put my charger on it. Didn't help. Checked batteries, one was at 500cca so I replaced it with a new 850 cca. Still slow turning. Checked starter, dying so I replaced it. Now I can turn it quickly but no joy. Tank down to just above empty so I added 5 gallons plus diesel cleaner. Nothing. Drained bowel, diesel came out. So now I've used the starter enough that it won't turn fast enough so I'm charging my jump box and then I'll see. FWIW, it was running just fine before all this happened. I've done a lot to it lately. The other battery in her is only a few months old. No codes coming up and no check engine lights. Any ideas and/or questions?? Please help!!!!!
markwemple is offline
post #2 of 57 (permalink) Old 10-07-2018, 09:18 PM
79jasper's Avatar
Is it registering on the tachometer while cranking?
Hear the fuel pump running?
Sent from my SAMSUNG-SM-G930A using Tapatalk
79jasper is offline
post #3 of 57 (permalink) Old 10-08-2018, 11:53 AM Thread Starter
As it's an 03, the tach check doesn't work. It isn't producing smoke. The fuel pump is working. It is cranking over unevenly.
post #4 of 57 (permalink) Old 10-08-2018, 01:47 PM Thread Starter
What does the lack of smoke mean? Anything??
post #5 of 57 (permalink) Old 10-08-2018, 02:11 PM
79jasper's Avatar
Lack of smoke means no fuel, or it's not firing the injectors.
I would look into the cps. May even try unplugging the icp sensor.
79jasper is offline
post #6 of 57 (permalink) Old 10-08-2018, 02:33 PM Thread Starter
OK. Can't remember when I last replaced the cps. So I'll stop by ford for one.
How does unplugging the icp help??
post #7 of 57 (permalink) Old 10-08-2018, 03:26 PM
RT
RT's Avatar
Unplugging the ICP sensor forces the PCM to use a default value. If the ICP sensor is reporting false data, the PCM would be setting the IPR valve in a position that could cause a no start or poor running condition. While you are up there unplugging the ICP sensor, make sure the IPR solenoid is in place and the tin nut hasn't backed off.
RT is offline
post #8 of 57 (permalink) Old 10-08-2018, 06:20 PM Thread Starter
Changed CPS. Now I have smoke but still no fire.
post #9 of 57 (permalink) Old 10-08-2018, 06:53 PM Thread Starter
Unplugged ICP. No change
post #10 of 57 (permalink) Old 10-09-2018, 08:33 AM
RT
RT's Avatar
If you have smoke, but no fire, you aren't generating enough heat to ignite the fuel. Slow cranking RPM, low compression, bad glow plugs, etc. Try plugging in the block heater for about 4 hours while running a battery charger to get the batteries topped off.
RT is offline
post #11 of 57 (permalink) Old 10-09-2018, 10:51 AM
You should have someone with the scan tool run a pressure test on those injectors, don't want to go to all that work taking everything apart to put glow plugs in and then repeat it over again putting injectors in.
bigred7.3psd is offline
post #12 of 57 (permalink) Old 10-09-2018, 11:01 AM
RT
RT's Avatar
OK - I'll bite. How do you do a pressure test on injectors using a scan tool?
RT is offline
post #13 of 57 (permalink) Old 10-09-2018, 02:02 PM
Auto Enginuity or Snap On scan tool performs a "buzz test" while displaying the pressure output of each injector. I had four dead injectors on one bank and it was firing like a V-4. I'm just saying you don't want to go through all that work replacing the glow plugs and put it all back together and it turns out to be the injectors. On mine before replacing the injectors, the ICP was good, glow plug relay replaced with the IPR also. Switched out the IDM to test and it ended up being the injectors, replaced with new Swamps 175cc street mild tow injectors with a tune.
post #14 of 57 (permalink) Old 10-09-2018, 02:09 PM
RT
RT's Avatar
I've done a few hundred buzz tests with AE and never saw a pressure readout. What exactly do you imagine is recording the pressure? AE can only look at data that is sent to the PCM. Are you thinking fuel pressure, cylinder pressure, or what?
RT is offline
post #15 of 57 (permalink) Old 10-09-2018, 02:21 PM
Sorry I am a bit vague, the one that ran the injector test was using a snap on scan tool, he showed me the readings of the pressure output for each injector and basically the problem was the injectors weren't building enough pressure for the engine to start. I don't know anymore details, but I was impressed.
