1995 7.3 rough running - Diesel Forum - TheDieselStop.com
post #1 of 26 (permalink) Old 03-11-2019, 05:17 AM Thread Starter
1995 7.3 no mods whatsoever with 111k miles. It will start and run but it runs as if half the injectors aren’t firing and the CEL will come on. It will run that way until I shut it off, which is pretty darn fast as I don’t want to make whatever is wrong worse than it is. I have replaced the CPS, checked the ICP valve for oil in the plug, there isn’t any, and left it unhooked and started the engine but it still runs horrible. I am new to all this so I don’t know where else to start troubleshooting or what I should be looking for. I don’t have a scan tool and I can’t get it anywhere to have someone read the code. The check engine light only comes on if it’s running and I don’t know if that’s how it’s supposed to work or not. Any help is greatly appreciated as this is a family truck and we don’t want to get rid of it and can’t afford to have someone else fix it.
Also the CPS I installed was from NAPA and had the gray body. From what I’m reading people are having trouble with aftermarket sensors so I’ve ordered the dark blue one from International.
Rigby76 is offline
post #2 of 26 (permalink) Old 03-11-2019, 08:44 AM
bugman's Avatar
My Photos: (12)
Without getting the codes read any answer will just be shooting in the dark, and shotgunning parts at is can get real expensive fast.
There are a couple of things that you can check real fast. Pull the oil fill cap off and smell the odor coming out of it to see if it smells like burnt wiring. You can also pull the plugs on the valve cover harness and look to see if the pins look burnt. You can also do a resistance check from the IDM wiring to see if there might be a problem with the wiring.
bugman is offline
post #3 of 26 (permalink) Old 03-12-2019, 01:03 PM Thread Starter
Thank you for the reply. I’ll check what you suggested. If the engine throws a code will the CEL be on the next time I go to start it, or does it only come on while the engine is running? What code reader can I get to get codes off the truck? The truck has the port under the dash on the passenger side but I’ve also read not just any reader can get the codes.
Rigby76 is offline
post #4 of 26 (permalink) Old 03-12-2019, 01:50 PM
bugman's Avatar
My Photos: (12)
There are a couple of cheap ways to read the codes on these trucks.
One is getting a OBD II adapter and then using a android smart phone, here is a thread on another forum about it.
https://www.powerstrokenation.com/fo...s-android.html
Another way is to use Forscan. It is a free program that runs on a laptop. You would need to purchase either a bluetooth OBD II adapter or a cord with a MS-Can & HS-Can switch on it. I use this cord.
Here is a link to Forscan
https://forscan.org/
And one to their forums
https://forscan.org/forum/
Then once you have the code you can check the code against this list to see what usually causes it for the repair.
https://www.thedieselstop.com/faq/94.../9596pced.php3
As for the CEL if the light came on there will be a code stored on the PCM until it is cleared.
Also if you are handy with a volt/ohm meter here is the test for the wiring coming off of the IDM to the injectors. This will tell you if there is a wiring problem such as a short, ground, open, and even if there is something going on with the injectors. Just as a FYI if the IDM recognizes a problem with the injectors on one side of the truck it will shut down that whole side until the problem either goes away or is fixed.
File Type: pdf GB_Tech_Bulletin_103_Ford IDM_Module_Replacement.pdf (710.5 KB, 8 views)
bugman is offline
post #5 of 26 (permalink) Old 03-12-2019, 04:02 PM Thread Starter
Pulled the IDM off and shook it and it has no water in it as far as I can tell. Shook it and no sound of water. Checked the resistance on everything in the harness from it and all the injectors tested 2.8-2.9 on all but one and that one had 3.1. Checked both IDM/ground and both were tested OL. Tested both power feed to injector ground shields and got OL on the right bank and 3.1 ohms on the left bank. Pulled the connector off the valve cover and the left female socket, holding it with the clip facing up, and looked like it was melted a little. Where do I go from here? New plug?
Rigby76 is offline
post #6 of 26 (permalink) Old 03-12-2019, 05:56 PM
bugman's Avatar
My Photos: (12)
Unplug the left bank harness from the valve cover gasket and test it again and see if you are still getting the 3.1 ohm reading. That may be your problem
If you still get the same reading then one of the connectors on that side just may be the problem.
Remember that there are 2 connectors on each valve cover gasket. Each one controls 2 injectors and 2 glow plugs.
bugman is offline
post #7 of 26 (permalink) Old 03-12-2019, 08:14 PM Thread Starter
I’m ordering the cable from Amazon you suggested and I have an old laptop with windows 10 on it that will run Forscan hopefully. I used the test procedure from http://gbreman.com/techbulletin_103.html to get my readings (sorry I don’t know how to use one word as a link). Is there a diagram somewhere that shows what wires are what on each of those plugs? Just so I know which wires go to what. Thank you for the continuous help.
Rigby76 is offline
post #8 of 26 (permalink) Old 03-13-2019, 12:39 AM
bugman's Avatar
My Photos: (12)
I don't have a wiring diagram to post but they are quite simple to figure out.
They go:
Glow Plug/Injector/common/Injector/Glow Plug
Just cut on the bad one with enough wire where you can tell what the colors are. Also when you replace the plug only use solder and heat shrink for the splices, no but connectors.
bugman is offline
post #9 of 26 (permalink) Old 03-14-2019, 04:30 AM Thread Starter
Ordered new repair plug, two new UVCH’s and a gasket. Just going to go ahead and replace it all while I have the valve cover off. Is there any bolts or nuts I should check to see if they’re loose while I have the valve cover offf?
Rigby76 is offline
post #10 of 26 (permalink) Old 03-14-2019, 09:49 AM
bugman's Avatar
My Photos: (12)
The only thing that I would do is to inspect the wiring going to the glow plugs and injectors. That along with doing a ohm test on each glow plug which should be between 0.6 and 2 ohms
bugman is offline
post #11 of 26 (permalink) Old 03-26-2019, 12:31 PM Thread Starter
I got the UVCH’s but they don’t have rubber boots on the injector connectors like the old ones I’m taking off do. I pulled one of the old ones off and tried using it on the new connector and it doesn’t want to go up into the female connector on the injector. Do they need the rubber boots?
Rigby76 is offline
post #12 of 26 (permalink) Old 03-26-2019, 07:16 PM
Patrick Feeley's Avatar
My Photos: (19)
No, the old style used the rubber boots. The new ones with the "Bail wire" retainers do not. Cheers!
97 F250 SC 4x4 (CA model), E4OD, 4.10 LS,
, Ext Trans Filter, Tru-Cool Max, I/C Mounted but not Plumbed
SOLD: 94 F350 CC DRW, 5 Speed, SBC Con-O,
, 3” DP, Bilsteins,
, Gutted EBPV
Patrick Feeley is offline
post #13 of 26 (permalink) Old 03-27-2019, 05:28 AM Thread Starter
Got to the point of snapping the injector connectors in and two were hard to get into the socket. Looked at the old wiring harness and two of the connector boots are not on there. Used an inspection mirror and noticed they’re stuck in the connector on the injector solenoid. Can I unbolt those four screws and pull the solenoid off to get the rubber boot out? If I can what do I retorque the bolts back to when putting it back on?
Rigby76 is offline
post #14 of 26 (permalink) Old 03-27-2019, 06:08 PM Thread Starter
Had to buy new batteries. Anyways I got the new UVCHs installed and fired the truck up and it’s still loping and smoking some. Got FORScan to work and I’m getting code P1280 and P0603. Is that telling me the ICP is bad. I even tried unplugging it and seeing if the truck would run but it won’t start at all.
Rigby76 is offline
post #15 of 26 (permalink) Old 03-27-2019, 07:08 PM
My Photos: (19)
Here's the pinpoint tests for P1280 if you are interested.
Z1 DIAGNOSTIC TROUBLE CODE (DTC) 1280: ICP CIRCUIT LOW INPUT
DTC 1280 indicates injector control signal circuit out of range low was detected during KOEO Self Test or during continuous diagnostic monitoring. Possible causes:
-- Biased ICP sensor/PCM
-- Open ICP sensor circuit
-- Short to SIG RTN or PWR GND on ICP sensor circuit
-- Open in VREF circuit
Disconnect ICP sensor connector. Key on/engine off. Measure voltage at VREF Pin B to battery ground.
Is voltage reading 5v ±.5?
Yes: GO to «Z2».
No: REPAIR open in VREF Circuit 351 (BR/W). CLEAR DTCs and RETEST.
Z2 SIGNAL RETURN CIRCUIT CHECK
Measure voltage from VREF Pin B to signal return Pin A. Is voltage reading 5v ±.5?
Yes: GO to «Z3».
No: REPAIR open in signal return Circuit 359 (GY/R). CLEAR DTCs and RETEST.
Z3 ICP SIGNAL CIRCUIT CHECK
Key off. Disconnect PCM. Inspect for loose, damaged or pushed-out pins. Repair as necessary. Check resistance from PCM Connector Pin 87 to Pin C at ICP sensor harness connector. Is resistance less than 5 ohms?
Yes: GO to «Z4».
No: REPAIR open in signal Circuit 812 (DB/LG). CLEAR DTCs and RETEST.
Z4 VREF CIRCUIT CHECK
Check resistance from PCM Connector Pin 90 to Pin B at ICP sensor harness connector. Is resistance less than 5 ohms?
Yes: GO to «Z5».
No: REPAIR open in VREF Circuit 351 (BR/W). CLEAR codes and RETEST.
Z5 SIGRTN CIRCUIT CHECK
Check resistance from PCM Connector Pin 91 to Pin A at ICP sensor harness connector. Is resistance less than 5 ohms?
Yes: GO to «Z6».
No: REPAIR open in SIG RTN Circuit 359 (GY/R). CLEAR codes and RETEST.
Z6 SENSOR SIGNAL CIRCUIT SHORT TO GROUND
Measure resistance from PCM Connector Pin 87 to PCM Connector Pins 25/51/76/77/91/103. Is resistance greater than 10,000 ohms?
Yes: GO to «Z7».
No: REPAIR short to ground in signal wire Circuit 812 (DB/LG). CLEAR DTCs and RETEST.
Z7 CHECK FOR SHORT ON PIN 87
Note: I’ve edited all the previous tests assuming you don’t have a “breakout box”. This test really requires one unless you want to probe the wires through the insulation with the PCM connected to the harness (all other tests had it disconnected).
Connect breakout box to PCM (without breakout box, reconnect the PCM to the harness and probe through the insulation). Measure resistance between Pin 87 and Pins 25/91/51/76/77 and 103. Is resistance greater than 10,000 ohms?
Yes: REPLACE ICP sensor. RERUN Scan Tool Diagnostic Test.
No: REPLACE PCM. REMOVE breakout box (disregard if you aren’t using one). RECONNECT ICP sensor. RERUN Scan Tool Diagnostic Test.
Cheers!
, 3” DP, Bilsteins,
, Gutted EBPV
Similar Threads
Need Help. 01 F250 7.3 Running Rough. Here's Diagnosis phigam07 '99 & up 7.3L Power Stroke Engine and Drivetrain 4 11-03-2011 07:14 PM
01' 7.3 Running Rough phigam07 '99 & up 7.3L Power Stroke Engine and Drivetrain 3 10-27-2011 06:15 PM
1999 7.3 running rough with bad miss abby '99 & up 7.3L Power Stroke Engine and Drivetrain 7 07-10-2007 01:42 PM
Will a 7.3L IDI crank fit a 6.9? rberner 6.9L IDI Diesels (Not Power Strokes) 6 05-03-2006 12:16 AM
whats the differance in a 6.9 and a 7.3 Abbey 7.3L IDI Diesels (Not Power Strokes) 2 04-24-2006 10:04 PM
