1995 psd Trans problem - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 03-30-2014, 12:45 AM Thread Starter
I have some issues goin on with my e4od. 1995 f250 diesel. 4x4.
Today when I took a trip on the interstate I noticed the torque converter locking and unlocking almost constantly. It would not stay locked unless I was accellerating putting on a load. I was pulling an empty car trailer. Did it all the way to my destination, then after I turned the truck off for a while the problem went away. Never had this problem before and ideas?
also something that It has always done and may be related, when in 1st the trans seems to slip. if im going down a gravel road and punch the throttle the tires dont spin at all. Is this the torque converter or something else?
Dmpaul89 is offline
post #2 of 8 (permalink) Old 03-30-2014, 02:46 AM
Low fluid level would be my first guess
1995 F250 PS. Stock with 190k. Auto
CornRickey is offline
post #3 of 8 (permalink) Old 03-30-2014, 06:44 AM
Mark Kovalsky's Avatar
My Photos: (6)
A wiring problem with the trailer is my guess.
Mark
Former
Automatic Transmission Engineer 1988-2007
Mark Kovalsky is offline
post #4 of 8 (permalink) Old 03-30-2014, 10:05 AM
I withdraw my guess and fully support Mark's
post #5 of 8 (permalink) Old 03-30-2014, 11:18 AM
flintshtr's Avatar
Problem in the brake wiring or ground to same will cause the Torque converter to unlock.
97 F-350-4X4-AUTO 355 GEARS--317,000+ MILES--ROSEWOOD STAGE 1 INJECTORS--SD HPOP--IDM MOD--BTS TRANS WITH SCHAEFER'S OIL --HYDROBOOST BRAKE SETUP-DPP DOWNPIPE--TS 6 POSITION CHIP--TYMAR INTAKE & HX MOD--HAYDON TRANS COOLER--FS 2500 BYPASS OIL FILTER--AMSOIL 5-30 OIL---EVANS COOLANT-203 STAT--WINDSTAR ELECTRIC FAN--DTRL--SYLVANIA SUPERSTAR BULBS- -ROYAL PURPLE SYNTHETIC IN BOTH REARS--WARN LOCKING HUBS--ISSPRO GAUGES IN AUTOMETER 3 GAUGE POD--XL CRUISE MOD--EXPLORER OVERHEAD CONSOLE-AC MOD--BILSTEIN SHOCKS--DB HT STARTER--WESTERN PLOW--CARGORAILS--NRA LIFE MEMBER--LIFE MEMBER SAFARI CLUB
1992 CONVERTABLE VETTE
1996 MERCEDES C280
1993 MERCEDES 190E
67 RS/SS CAMARO
2004 325I WAGON
flintshtr is offline
post #6 of 8 (permalink) Old 03-31-2014, 11:11 AM Thread Starter
Ok I can see how the trailer may be the problem, my lights are all rigged up. but wouldnt that be a constant issue instead of intermittant? and the problem of slippage in 1st happens with nothing hitched to the truck as well. Thanks for the replies
Dmpaul89 is offline
post #7 of 8 (permalink) Old 03-31-2014, 11:12 AM Thread Starter
And I did check my third brake light it is working
Dmpaul89 is offline
post #8 of 8 (permalink) Old 03-31-2014, 12:11 PM
Have you looked at the harness on the truck side? I've had wires with a single braid come loose inside the plug and mess with things. Also possible someone did a hack job on the truck harness to put the plug in and has something messed up. Intermittent problems always seem to come back to a ground wire somewhere.
AaronSEIA
My Truck:
97 F250 4 door shortbed, E4OD
DIY intake
Kingpin Dana 60
otherwise stock
AaronSEIA is offline
