1996 7.3 - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 12-27-2018, 04:26 PM Thread Starter
Was working on my 96 7.3 and took the chip out and my friends didn’t know that u couldn’t plug it in while running killer the truck and now WTS light won’t come on is it a fuse or something else needing help fast
Cdean is offline
post #2 of 6 (permalink) Old 12-27-2018, 06:05 PM
bugman's Avatar
My Photos: (12)
If there was power to the PCM then odds are you killed it.
bugman is online now
post #3 of 6 (permalink) Old 12-28-2018, 12:58 PM Thread Starter
So what do I need to buy
Cdean is offline
post #4 of 6 (permalink) Old 12-28-2018, 03:07 PM
bugman's Avatar
My Photos: (12)
A rebuilt PCM.
Get the code off of the one in the truck now. The big difference is the transmission. The ones for a manual will not work in a truck with a automatic but the ones for a automatic can be used in a manual with some work. Also one from a 99+ year truck will not work without modifications and there is a difference between a truck that was sold in California vs one from the other 49 states
There are quite a few on Ebay and perhaps a local auto parts store might be able to order one for you.
post #5 of 6 (permalink) Old 12-28-2018, 03:43 PM Thread Starter
Thanks man appreciate it I thought that’s what it was but didn’t know if it could a fuse or the glow plug relay
Cdean is offline
post #6 of 6 (permalink) Old 12-28-2018, 04:10 PM
bugman's Avatar
My Photos: (12)
It is one of the problems with running a chip that is attached to the PCM.
It has been said to put the keys to the truck in you pocket before even looking at it. Others have gone as far as disconnecting the battery before installing or removing a chip out of the PCM.
Good luck.
