1996 7.3 - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 12-29-2018, 02:58 PM Thread Starter
I have a 1996 7.3 auto 4 wheel drive anyone know if this is the right pcm or which one do I need
Cdean is offline
post #2 of 9 (permalink) Old 12-29-2018, 03:40 PM
bugman's Avatar
My Photos: (12)
That is the IDM that drives the injectors.
The PCM is located behind the trim and emergency brake assembly. If you look down the drivers side fender on the firewall you will see the connector.
Here is a set of instructions on putting in a chip which shows how to pull the PCM.
https://www.totaldieselperformance.c...stall94-97.pdf
bugman is online now
post #3 of 9 (permalink) Old 12-29-2018, 04:06 PM
bugman's Avatar
My Photos: (12)
What was being worked on when the chip was removed or tried to be reinstalled?
A performance chip is installed in the PCM and not the IDM. If the work was being done around the IDM I would check the fuses under the hood #22, #9, and #8. If it is related to killing the truck those fuses will do it.
post #4 of 9 (permalink) Old 12-31-2018, 09:25 PM Thread Starter
My buddy plugged the chip in while it was running and killed it so what did it mess up and what do I need to buy
Cdean is offline
post #5 of 9 (permalink) Old 12-31-2018, 11:14 PM
Patrick Feeley's Avatar
My Photos: (19)
You most likely fried the PCM, which as mentioned is down low on the firewall. It comes out through the engine compartment. You can read the program code using a flashlight and mirror (and deciphering the backwards text). It should be a DPC-202 family of PCM (49-state, automatic trans) and then have an alphanumeric code such as TDE0 or NAW4, etc. Cheers!
97 F250 SC 4x4 (CA model), E4OD, 4.10 LS,
, Ext Trans Filter, Tru-Cool Max, I/C Mounted but not Plumbed
SOLD: 94 F350 CC DRW, 5 Speed, SBC Con-O,
, 3 DP, Bilsteins,
, Gutted EBPV
Patrick Feeley is offline
post #6 of 9 (permalink) Old 01-01-2019, 10:52 AM Thread Starter
Thank u all so much one more question the part that drives the injectors is that the right code for the truck it’s from a junk yard from the guy before and the truck misses out and runs like **** could that be the wrong one or would that cause it to run bad
Cdean is offline
post #7 of 9 (permalink) Old 01-01-2019, 11:44 AM
bugman's Avatar
My Photos: (12)
On the injector driver module (IDM) any one of them from a 1994 to a 2003 will work.
A miss can be caused by a lot of different things but one of the big things with these trucks in the wiring that goes through the valve cover harness to the injectors. The glow plug wiring will burn the connectors to where the injector wiring will start to short out causing a problem.
post #8 of 9 (permalink) Old 01-01-2019, 03:12 PM Thread Starter
So the pcm is what the chip plugs into correct ?
Cdean is offline
post #9 of 9 (permalink) Old 01-01-2019, 07:52 PM
bugman's Avatar
My Photos: (12)
Yes, the chip connects into the PCM
