1997 7.3L cuts off while pulling - Diesel Forum - TheDieselStop.com
post #1 of 12 (permalink) Old 03-20-2016, 07:31 PM Thread Starter
Hello all. Thanks for help in advance
I have a 1997 7.3 f250
I had to pull a buddy of mine out of ditch today.
I locked my truck in 4wd low. Started to pull and the truck cut off. This happened several times. While I was pulling the truck was on about a 30 degree incline.I then drove the truck to get another buddies truck and it drove 100% fine.
It always started right back up with no problems.
It is tuned by dp tuner. Don't no if this matters.
What could this be?
Bhollins3 is offline
post #2 of 12 (permalink) Old 03-21-2016, 05:32 AM
ArcticDriver's Avatar
Welcome to the forum.
I will leave the troubleshooting to more knowledgable guys but it might be a good idea to let your EOT get up to operating temp (180*+) before you ask it to do work like that.
Thats what I was always taught with equipment, anyway.
SOLD:
ArcticDriver is offline
post #3 of 12 (permalink) Old 03-21-2016, 06:18 AM Thread Starter
I always like to and have in the past. He was in a sticky spot.
First diesel so I wasn't sure if that would make it cut off, why I thought it would be a good idea to put that info in there.
Thanks man
post #4 of 12 (permalink) Old 03-21-2016, 06:24 AM
Thanks man
I understand about sticky spots.
I don't think your engine cutting out was a result of it not being warned up though so you should get some expert responses soon.
SOLD:
post #5 of 12 (permalink) Old 03-21-2016, 10:49 AM
Automatic or manual transmission?
madpogue is offline
post #6 of 12 (permalink) Old 03-21-2016, 12:02 PM Thread Starter
Automatic
post #7 of 12 (permalink) Old 03-23-2016, 10:50 PM
Kevin 007's Avatar
Was the truck twisting at all when you were pulling? Sometime bad wiring can rub up on something when the truck is torqued out
1984 F-250 6.9, T-19, BW1345, BB code injectors, low mileage, manual Beru Glow Plugs, D70 rear end. solid truck.
1985 Toyota Landcruiser BJ60, 5 bearing cam 3B 4cyl diesel, H55F trans. Best rig I have ever owned.
1981 Honda Trail 110.
Kevin 007 is offline
post #8 of 12 (permalink) Old 03-24-2016, 07:03 AM Thread Starter
I do not recall that it was.
post #9 of 12 (permalink) Old 03-24-2016, 05:55 PM
How is your oil level? Incline could cause low oil to run away from the sump making low oil flow to the HPOP. A restart would give the oil in the heads time to flow down.
AaronSEIA
My Truck:
97 F250 4 door shortbed, E4OD
DIY intake
Kingpin Dana 60
otherwise stock
AaronSEIA is offline
post #10 of 12 (permalink) Old 03-24-2016, 08:03 PM
Do you tow a trailer?
Maybe you could try and replicate the issue by putting a similar load on your engine while monitoring gauges?
SOLD:
post #11 of 12 (permalink) Old 03-24-2016, 08:50 PM Thread Starter
AaronSEIA
Oil is spot on. Doesnt leak and 0 blow by.
post #12 of 12 (permalink) Old 03-24-2016, 08:52 PM Thread Starter
I do. My buddy has a diesel shop with heavy dump trucks 18 wheelers ect. Plan to put one in neutral and pull one this weekend for load. Maybe this will be good enough?
I have been driving truck everyday since this happened with 0 problems. Just don't want it to happen again
