1997 PSD transfer case shift linkage - Diesel Forum - TheDieselStop.com
post #1 of 2 (permalink) Old 03-31-2014, 08:30 PM Thread Starter
My new transfer case shift linkage came in. Does anyone have tips/suggestions on replacing it? I read it's a good idea to lubricate the
shift rod. Any suggestions to make it easier to install or last longer
would be appreciated. Thank you!
1997 F250 HD PSD 4x4 OR Auto 3.55LS CC SRW SWB 265x75x16 Michelin LTX DP 211K mi.; Ford AIC; Fuel milege; 20.3 mpg @ 70 mph. 12.5 mpg pulling my boat,12.5K, along two lane rural roads. A number of mods ordered from DaleI. Nice round replacement DP. FS2500 by-pass oil filter installed. Fumoto drain valve. Tymar Intake installed! HX mod from Tymar installed. TFI fillneck kits installed. Auto-Rx cleaner in engine & transmission done. Switched from Rotella dino to Rotella synthetic. Amsoil 5W-30 Series 3000 installed!
FS-2500 Bypass filter installed. CD Changer
Velvet rides installed. Joe Servo IDM mod was installed. Replaced with Swamps HV/HF IDM! Rear air lift springs. 4" exhaust installed all the back from DP and bye bye Kitty.
Sparkydm is offline
post #2 of 2 (permalink) Old 04-01-2014, 01:24 PM
jimzpsd's Avatar
I drilled and tapped two zerk fittings at the pivot points on the aluminum housing, so when I'm under it next time I can lube the inner shaft.
1997 F-350 XLT, 4wd, crew cab, E-4OD,TDE-1, 4:10's (sold it, has 328k miles)
2017 F-350 XLT, 4wd, CC, LB
jimzpsd is offline
