4 cylinder powerstroke - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 09-17-2006, 09:44 PM Thread Starter
SMF
Sorry, It's not what you think, the guy across the street for me has a 96 PS that is running on just the drivers side. We checked the exhaust temps with a infared and all cylinders on the passenger side were cold. The fuel system is way different than on mine, I was woundering if it is possible to have fuel to one head and not the other? any ideas?
Thanks for your help
Steve
99.5 F-350 XLT 4X4 CC DRW PSD 6spd 4.10's, Predator, serve duty intake, 3" exhaust no muffler, intank & prepump, Autometer phantom boost & Pyro gauges, 230,000 miles, new injectors at 213K.
SMF is offline
post #2 of 6 (permalink) Old 09-17-2006, 09:46 PM
Re: 4 cylinder powerstroke
Wire harness or/and burn't pins shorting out the side. remove the oil fill cap and sniff with the truck OFF. Burn't smell means 'Parts from International time'. [img]/ubbthreads/images/graemlins/grin.gif[/img]
95 F250,XLT, 4WD, Auto Trans,bbshimmed,synthetic trans oil,4:10 gears ,Truck Trunk ,Nerf Bars ,crome Mud flaps, Aux. trans cooler, front diff. drain plug. External trans.filter, trimmed snorkel. American wheels water temp guage, front fuel tank mod,Warn Manual hubs,Putman class 4 hitch 212k mi.
Currently also have 2012 Dodge 4X4 with a Cummins engine.
It is said if you sit by the river and watch the water flow by long enough, your enemies will pass by. This I believe to be true. It is also possible to watch your loved ones pass by as well.
Wife Candi 08/14/07 missing her always
Gone Fishen is offline
post #3 of 6 (permalink) Old 09-17-2006, 09:53 PM
kfjensen's Avatar
Steve
Just pull the plugs that plug into the valve cover gaskett (two on the inside of each valve cover) if it is burnt at all glow plug shorted back and need to pull valve cover, replace at LEAST burnt plug and any other damage such as plugs.
Kevin
94.5, PSD, F-250, 4x4, Handshaker,
kfjensen is offline
post #4 of 6 (permalink) Old 09-17-2006, 10:38 PM Thread Starter
SMF
Thanks Guys
I called him and he pulled the connectors. I went over there and we both agree that the back one smells just a little burnt. The back one was also very wet with engine oil, wasn't wet on the outside just the inside, looks like fresh engine oil. He's going to pull the valve covver tomorrow. It' been a while since I checked glow plugs, If I remember right, .6-6 ohms is good?
Thanks again
Steve
SMF is offline
post #5 of 6 (permalink) Old 09-18-2006, 10:19 PM Thread Starter
SMF
Thanks guys, your answers were right on. The harness inside the valve cover was toast. Are the replacements new and improved?
SMF is offline
post #6 of 6 (permalink) Old 09-18-2006, 11:38 PM
I just did mine I bought my parts from Ford cost me around $50 for the valve cover gasket and around $50 for the harness
2016 F-3506.7 PSD, Crew Cab, Long bed, Lariat with the Ultimate package, Fx4, Bench seat in the front, tan interior, white platinum with Caribou accent 5th wheel prep package, 3.55 rear end with Electronic lockers - Purchased New, I've Added Cab Lights, and Heated Steering wheel, Also made the Aux switches always hot so I can turn on lights even if the truck is off
2002 F-350 Crew Cab Long Bed, Lariat, 4x4, Automatic, , In-Tank Hutch Mod, Edge Insight Monitor. 330k miles
Sold - 2000. Stock F-350 XLT 330K+ miles, white, 4x4, 6 spd manual, extended cab, Long Bed. Marinco Block Heater Mod, Tymar Intake. 4" Turbo Back Straight pipe, In-Tank Hutch Mod, Swamps Diesel 175/146 injectors - with TS Performance 6 position chip
jchipper is offline
