7.3 powerstroke won,t start - Page 3 - Diesel Forum - TheDieselStop.com
 1Likes
post #31 of 36 (permalink) Old 04-13-2019, 09:24 AM
Patrick Feeley's Avatar
My Photos: (19)
On the IPR, the Red wire is battery voltage and the Yellow/Red stripe wire is the ground (provided by the PCM when commanded). Cheers!
97 F250 SC 4x4 (CA model), E4OD, 4.10 LS,
, Ext Trans Filter, Tru-Cool Max, I/C Mounted but not Plumbed
SOLD: 94 F350 CC DRW, 5 Speed, SBC Con-O,
, 3 DP, Bilsteins,
, Gutted EBPV
Patrick Feeley is online now
post #32 of 36 (permalink) Old 04-21-2019, 04:34 PM
narmalee's Avatar
Originally Posted by rayroof10 View Post
Also have 26 psi fuel pressure . And no smoke out of tail pipe while cranking
you need 50 minimum... 55-65 recommended, that's why we all switch to e-fuel, the factory m-pump SUCKS
-'97 F250HD 4x4 7.3-
-'99 Cobra 426w-
-'76 LS408 Stingray-
-'93 302 Camaro on the juice-
narmalee is offline
post #33 of 36 (permalink) Old 04-21-2019, 11:11 PM
We don't "all switch". My mechanical pump lasted 21 years. I changed it then only because it was easy to get to.
tbeck likes this.
Kimber1911 is offline
post #34 of 36 (permalink) Unread Today, 02:40 AM Thread Starter
Been awhile since I have been on here. On my 95 f350 that wouldn't start wound up changing out fuel pump and HPOP also the ipr valve. She's running like a champ. Thanks to everyone who helped me on this problem. This forum is the best. Thanks again.
rayroof10 is offline
post #35 of 36 (permalink) Unread Today, 02:47 AM Thread Starter
1995 F350 injector has a knocking sound
When l start my truck it has a knocking sound. Not bad but it's on passinger side and while driving you can,t hardly hear it. How do l locate which injector is bad. Thanks
post #36 of 36 (permalink) Unread Today, 09:36 AM
bugman's Avatar
My Photos: (12)
To do it right you need a break out box that will shut down each injector individually.
But without one you can pull the valve cover and disconnect each injectors wiring and find it that way.
bugman is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Patrick Feeley
Similar Threads
7.3 Bulletins Part 1 DieselDog2 '99 & up 7.3L Power Stroke Engine and Drivetrain 7 02-08-2014 10:06 AM
7.3 powerstroke wont start please help (update) jesel45 '99 & up 7.3L Power Stroke Engine and Drivetrain 7 05-18-2010 05:23 AM
HELP!! 6.9 -7.3 I.D Questions / Core Guys LowProPusher 6.9L IDI Diesels (Not Power Strokes) 9 03-03-2009 10:46 AM
03 F250 7.3 Powerstroke Turbo Diesel slow to start when cold ThreeFordTrucks '99 & up 7.3L Power Stroke Engine and Drivetrain 5 12-10-2008 07:36 PM
7.3 powerstroke no start 99 f-450 hatchetdog '99 & up 7.3L Power Stroke Engine and Drivetrain 4 04-20-2005 08:57 PM
