'95 tranny died, swapped in a '96 - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 03-01-2009, 08:18 PM Thread Starter
Ok, on the one two shift my tranny died in my '95 F350. I bought the truck used about 20k mi ago. I think it has a chip, it will run right along with my 04 dodge cummins. swapped in a tranny out of a '96 with a fresh rebuild, now I have a flashing od light. Are these two trannies compatible, or do I need to swap the ecm's out if I didn't have a shift kit in the '96. Any help would be great. TIA
Geoffb18610 is offline
post #2 of 10 (permalink) Old 03-02-2009, 12:53 PM Thread Starter
Any help at all?
post #3 of 10 (permalink) Old 03-02-2009, 01:28 PM
Send a message via AIM to rockets10510
maybe give people a little bit of time to reply. the people that know a lot usually reply at night. but from what i know they should swap. and no you do not need to swap pcms or ecms. do you have a way to pull the code?
anthony
1997 F-350 2WD SRW White Crew-Cab Bought in 3-05 w/196,xxx miles 280,xxx miles, 4" exhaust, tymar, oil bypass changed oil at 10k, TW 6 pos chip, stage 1 DIY injectors, fully build racerx trans, B & W turn over, coolant bypass filter, intercooler.
Parts Replaced:
Water Pump 213,000 $120.00 Napa
Alternator 224,000 $64.00 Ebay
Fuel Pump 221,000 $64.60 Ebay
Radiator Core 252,000 210.00 (All Alum) Preference Radiator
Fuel Bowl 262,000 NEW from Ford $348.00
rebuilt trans my self with racerX parts. 265,000 $2800.00
DIY Stage ones 267,000 $350.00
Waterpump 265,250 $70 Thedieselstop
Flexplate 280,000 $85.00 autozone
1997 Ford F350 2WD SRW Green Crew cab bought 06-07 with 232,000 miles, Now 238,xxx miles, AFE exhaust, oil bypass, coolant filter, , 6pos Tony Wildman Chip
Parts Replaced
Fuel Pump 234,000 $65.00 Ebay
Ford Reman Trans 234,000 $2100.00
rockets10510 is offline
post #4 of 10 (permalink) Old 03-03-2009, 06:37 AM Thread Starter
I can take to a shop and get the code pulled. I don't have a way to pull it myself. Sorry for my impatience. My guy took it to a shop, he pulled a faulty relay code, and a TCC code. The tech seemed to think he cleared a blockage in the cooler, and solved the problem. Clearly that wasn't the case. Thanks for any help. TIA
post #5 of 10 (permalink) Old 03-03-2009, 09:15 AM
give racerx a call. he is really good on helping. his number is on his site Racer X Automotive
he has helped me out a lot.
anthony
Parts Replaced:
Parts Replaced
post #6 of 10 (permalink) Old 03-03-2009, 09:18 AM
Flashing OD light is for a slipping or failing torque converter. Did you install a new tc when you swapped the tranny?
Good Luck
Midwestman
95 350 CC SRW 4X4.500K. Amsoil everwhere w/dualbypass filter. Early Centurion model custom paint (white with grey striping) Grey shell, brushguard, Flexsteel leatherseating wood trim and overhead console. BTS hold on tight E4OD tranny. Custom chip by Cale Thompson at BTS. Hypermax DP. Tymar Open element intake. Tru-Cool 28,000 GVW trans cooler plus Super Duty trans cooler. Super Duty Intercooler with GTS pipes. CCV mod. 3 pod A pillar guages with Isspro Pyrometer,Boost and Tranny temp guages. Fumoto oil drain. John Deere coolant eye. Sylvania Ultra Silverstars. Joe Servo IDM. BABY SWAMPS. Magnaflow 4" exhaust. Tymar Coolant Filter. Sirius satellite radio. Kelderman Air Ride on the rear. Autolights clear diamond headlights. Mods as the budget will allow.I think I am almost finished.
midwestman is offline
post #7 of 10 (permalink) Old 03-03-2009, 02:47 PM Thread Starter
I did nnot install a ne TC when i swapped. It was a fresh rebuild, maybe 35k on it. Wouild you still recomend the new TC>
post #8 of 10 (permalink) Old 03-03-2009, 10:34 PM
Good Luck
Midwestman
that is not always the case. it could be a failed clutch pack as well. will the truck lock or does it just slip? also are all the wires connected?
anthony
Parts Replaced:
Parts Replaced
post #9 of 10 (permalink) Old 03-04-2009, 09:55 AM Thread Starter
The truck locks and works well, then for no apparent reason unlocks. I do have a temp gauge that seems to go up and down. looks like a sticky thermostat. Will the fluctuation in temp cause a problem?
post #10 of 10 (permalink) Old 03-04-2009, 10:08 AM Thread Starter
I was going off my guy's word who has been driving it. No, no TCC lockup.
