'97 drivetrain upgrades - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By klhansen
post #1 of 3 (permalink) Old 04-03-2019, 10:30 PM Thread Starter
MontanaCowboy's Avatar
I own an all original '97 F350 crew cab 4x4 with the 7.3 and automatic transmission with 230,000 miles. I have the opportunity to buy a similarly equipped but totaled 03 F350 with 105,000 miles on it for $5,000. I was originally just looking at doing an engine swap, but now I'm thinking engine, transmission, transfer case, etc. I don't intend to swap my Dana 60.
What all can be swapped over, and why should I or shouldn't I?
Thanks,
MontanaCowboy is offline
post #2 of 3 (permalink) Old 04-04-2019, 12:01 AM
bugman's Avatar
My Photos: (12)
It all can be swapped if you have the time and money.
I presume that the 03 has the 7.3, if not I would forget it.
But by the time you are done all you will have as far as you 97 is the body.
bugman is offline
post #3 of 3 (permalink) Old 04-04-2019, 12:59 AM
klhansen's Avatar
My Photos: (180)
Don't swap just one axle, unless you want different lug pattern wheels front to back. 99 and up are 8 on 170mm versus the earlier 8 on 6.5 inch pattern.
tbeck likes this.
), AIS,
regulated return,
klhansen is offline
Similar Threads
6.0 Preventative Upgrades WhiteDiesel07 Upgrades and Aftermarket - 6.0L Engine 6 12-30-2012 06:05 AM
2007 F-350 DRW: DD/TOW Upgrades w/o a Tuner colo_dually Upgrades and Aftermarket - 6.0L Engine 20 12-27-2010 11:51 PM
Upgrades Step #1 - BTS Valve Body 70Standard '99 & up Upgrades and Aftermarket - 7.3L Engine 10 05-07-2009 05:38 PM
Drivetrain "slack" question jat99 '99 & up 7.3L Power Stroke Engine and Drivetrain 13 03-24-2005 11:26 PM
