97 starter will not crank engine - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 09-07-2019, 03:53 PM Thread Starter
97 power stroke starter engages but will not turn the motor, put in a new starter, starter relay, batteries are two years old and show 12.4 volts it engages and sounds like the starter motor is spinning but it won,t turn the engine can the batteries show good voltage but still not be able to turn the engine.
BIRDNBUCK is offline
post #2 of 3 (permalink) Old 09-07-2019, 04:14 PM
bugman's Avatar
My Photos: (12)
I'd pull the inspection cover and take a look at the flexplate if it is a automatic or flywheel if a 5 speed.
You also might of gotten a bad starter.
bugman is offline
post #3 of 3 (permalink) Old 09-07-2019, 10:18 PM
Patrick Feeley's Avatar
My Photos: (19)
I'm assuming the motor actually spins? You should be able to rotate it with a breaker bar/socket on the crank pulley. Cheers!
97 F250 SC 4x4 (CA model), E4OD, 4.10 LS,
, Ext Trans Filter, Tru-Cool Max, I/C Mounted but not Plumbed
SOLD: 94 F350 CC DRW, 5 Speed, SBC Con-O,
, 3 DP, Bilsteins,
, Gutted EBPV
Patrick Feeley is offline
