ABS Light issues Part II - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 05-30-2006, 11:49 AM Thread Starter
Leroux's Avatar
Will a vacuum pump thats going bad cause an ABS light to come on on startup? Ive been batteling the ABS light for a couple months and am down to either vacuum pump or RABS sensor. I just bled all brakes and RABS sesor to check if there was air, and everything looked fine.
2000 F250 Lariat, CA Emissions, CC, Long Bed PSD, 4x4, Manual, 4.30 gears, 102K Miles
Performance Mods: Tuned by PHP, Gauges, AIH Delete, 5" straight exhaust, DIY Intake
Suspension: Fabtech all spring 8" Lift, Fabtech Dual Front shock mounts, Fabtech Dual steering stabilizer, Bilstien 5125 on corners, 17" ATX Vice, 37" Toyo M/T
1995 Ford F350 PSD
Leroux is offline
post #2 of 7 (permalink) Old 05-30-2006, 01:01 PM
My Photos: (18)
Re: Vacuum pump cause ABS?
Yes it will make the ABS light come on if it is going bad, mine did right before my vaccum pump died.
TCH777 is offline
post #3 of 7 (permalink) Old 05-30-2006, 02:27 PM Thread Starter
Leroux's Avatar
Thanks!
1995 Ford F350 PSD
Leroux is offline
post #4 of 7 (permalink) Old 05-31-2006, 11:46 PM Thread Starter
Leroux's Avatar
I changed the vacuum pump and that didnt fix anything. But I did find something odd. If I hold down the brake pedal when I start up the truck the light never comes on until I release it then it comes back on. Does that have anything to do with my problem?
1995 Ford F350 PSD
Leroux is offline
post #5 of 7 (permalink) Old 06-01-2006, 12:34 AM
isn't that plug on the rear end have something to do with the abs , or is it just a speed sensor? Anyway i thought if it was loose the ABs light would come on...I COULD BE WRONG
daveUza is offline
post #6 of 7 (permalink) Old 06-01-2006, 08:47 AM Thread Starter
Leroux's Avatar
DaveUza, you are correct. That is the Vehicle Speed Sensor, or RABS sensor. I have replaced that along with bleeding all the lines.
1995 Ford F350 PSD
Leroux is offline
post #7 of 7 (permalink) Old 06-02-2006, 08:48 PM Thread Starter
Leroux's Avatar
Anybody else have any ideas? I just replaced the brake pedal switch and that wasent it.
1995 Ford F350 PSD
Leroux is offline
