Alternator Smoke - Page 2 - Diesel Forum - TheDieselStop.com
post #16 of 22 (permalink) Old 02-21-2009, 01:22 PM
RoGrrr's Avatar
Send a message via AIM to RoGrrr
Alternator Size
Originally Posted by xfordtdm View Post
I used to test and build Ford alternators at the Rawsonville Ford plant. The voltage regulators rarely go bad, it's the brushes that wear out. The dealer will sell you a set for about five bucks. Your alternator is a 3G model.
I believe your rectifier is fried. The plasma coating on the rectifier probably got fried when the diodes cooked. That black crusty stuff is plasma coating. Just get a reman and be done with it.
So what is the biggest alternator I can get and mount in the same place on my 96 7.3 PSD ? I plan to install some MONDO lights on my F250. You know, lights that will simply blow that other driver OFF THE ROAD when I turn them on. (figuratively, you know)
RoGrrr is offline
post #17 of 22 (permalink) Old 02-21-2009, 04:34 PM
xfordtdm's Avatar
Good question. We manufactured over 100 different 3g models. I don't own my 97 anymore but I think it was 130 amps. This is more than your truck should ever need. There is a bearing cove on the back of the alternator that has an ink jet print on it. It should say the amperage.
I purchased my 2001 with dual alternators. Way overkill.
xfordtdm is offline
post #18 of 22 (permalink) Old 02-21-2009, 05:49 PM
Hey, when I Googled 3G alternators I found this site
http://www.alternatorparts.com/3G_products.htm
and they also have the pigtail I believe.
'94 F250 supercab 4x4, original owner, 4.10LS, DIY elec fuel, Tymar air intake, Adrenaline HPOP, Beans tunes on 4 position VA chip, VDO gauges (boost,pyro, outside temp), Ford digital AIC, DPPI downpipe, gutted EBPV and turbo pedestal mod, Con OFE clutch, add-a-leafs front and rear, Monroe Reflex shocks, Milemarker 449SS hubs, towing 25' Mallard travel trailer
coming soon: 6.0 IC
nashvillebill is offline
post #19 of 22 (permalink) Old 02-24-2009, 12:01 AM
xfordtdm's Avatar
Ford Motorcraft 3G type Alternators, Ford alternator repair
Yup, thems the parts!!! Good call. Ford stopped making alternators about 4 months ago.
2001 f250: AFE stage 2, Banks Monster exhaust w/power elbow and bighead wastegate, autometer pillar guages, kcm crossover, ccv delete, ITP over boost annihilator, dp 6 pos stock, 40,60,80econ,100,120, BTS Tranny, FS2500 soot sucker bypass oil filtration.
xfordtdm is offline
post #20 of 22 (permalink) Old 02-24-2009, 08:29 PM
So...I still have my original alternator after 15 years and 110,000 miles. Would it be cost-effective to rebuild this alternator myself (new rectifier, regulator, and bearing) or cheaper just to buy a rebuilt one from aftermarket store? Am I overlooking any other parts I'd need, and is there anything special about rebuilding it?
p.s. I'm not having trouble (yet) but thinking about future preventive maintenance.
coming soon: 6.0 IC
post #21 of 22 (permalink) Old 02-27-2009, 11:02 PM
RoGrrr's Avatar
200 AMP Alternator
Between xfordtdm and nashvillebill, I think I know what to look for now. Alternators aren't all that complicated and if I can physically fit a 200 to my belt setup, I'll be good to go.
I want to support a 100 watt police siren/PA-System, a compressor to run my air horns and a 100 Amp 110volt AC generator to run other accessories. The 200 should fill the bill quite nicely. IF I can find one....
RoGrrr
RoGrrr is offline
post #22 of 22 (permalink) Old 02-28-2009, 11:36 PM
Not sure where to find it...
I have seen several places over the years that offer a high output style that was made for ambulances.... its been a while since I looked but I am sure they are still out there....
quadrider400 is offline
