Ball Joints, U Joints anything else? - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 08-18-2018, 09:41 AM Thread Starter
dirtyb15's Avatar
Hello all. Both my upper ball joints are shot in my 96 f250 4x4. Can these be replaced without removed the lowers? Should bearings be done at this time? I may replace all but money is tight at the moment. I also need to replace the driverside front axle u-joint. Can anyone tell me what all parts / tools i will need for this job? (I have been searching for how to's etc.. but still not positive what all i need as far as seals etc..)
Thanks!
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hub: 321,000 miles
dirtyb15 is offline
post #2 of 4 (permalink) Old 08-18-2018, 01:22 PM
klhansen's Avatar
My Photos: (180)
The lower ball joint needs to come out before you can remove the upper, so you might as well replace both. They're likely worn out as well. Depending on mileage and condition when you remove them, your wheel bearings are likely OK. Just clean, repack with grease and reinstall.
You'll need a ball joint press and the appropriate adapters. You can probably get those from your local auto parts store. Most will loan them to you with a deposit that's refunded on return.
The parts store should be able to help you on seals as well. Unless the differential seal is currently leaking, leave that alone. The differential carrier needs to come out to replace the diff seals. There should be a dust seal just inboard of the u-joint, which should be replaced, as well as the seal outboard of the u-joint. Also the wheel bearing seal that goes on the inner side of the hub after the inner bearings are installed.
), AIS,
regulated return,
klhansen is offline
post #3 of 4 (permalink) Old 08-19-2018, 07:49 AM
If you are that far in, take a good look at the brake rotors. I know you say money is tight and I've been there, but if you can swing it, I'd at least throw rotors at it if they look close to needing replaced.
AaronSEIA
My Truck:
97 F250 4 door shortbed, E4OD
DIY intake
Kingpin Dana 60
otherwise stock
AaronSEIA is offline
post #4 of 4 (permalink) Old 08-21-2018, 07:48 AM Thread Starter
dirtyb15's Avatar
Thanks for the info. It looked like the lower had to come out before doing the upper.
Hope i can get this all done in a day.
dirtyb15 is offline
