battery light / alternator? - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 04-21-2008, 05:03 PM Thread Starter
greenskeeper79's Avatar
Battery light comes on only at idle, any bit of pedal and it goes off. Checked the 3 small wires going from the alt and they look ok, the large single has 12.6v when connected. However, when disconnected the post it was connected to only has 6v. Is this a sign of a bad alt? I think it is the original which would be 11yrs/145k miles!
Gunga galunga...gunga -- gunga galunga.
97 F-250 CC 4x4 7.3L PSD E4OD
99 F-250 CC 4x4 7.3L PSD ZF6 E99 CALI DELETE
ROTELLA 5W-40, MOBIL1 ATF, PENNZOIL SYNCHROMESH
greenskeeper79 is offline
post #2 of 8 (permalink) Old 04-21-2008, 05:57 PM
ammayernick's Avatar
Are the batteries in good shape? Do you have a voltmeter? If so, check the voltage at the batts while running - should be 14.5 volts or so. Then pull the positive cables and check when not running - should be 13 volts to13.6 volts. Usually a defective Ford alternator will drain the batteries even when not running. Good Luck.
2011 F350 CC Lariat 6.7 4x4 Tuxedo Black Loaded* ICON 4.5 inch Stage II with 4 link and Deaver Mini-Paks * OUO 5" Traction Blocks & Bars * 20" BMF Novakanes with 37x12.50x20 Nitto Trails * ICON Dual Steering Stabilizer * RECON Projectors, Mirror, 3rd brake, Cab,and Tailights * Pace Edwards Bedlocker * EPIC Door Seal Mods * AMP Research Steps *
ammayernick is offline
post #3 of 8 (permalink) Old 04-22-2008, 03:18 PM Thread Starter
batteries are good, less than 1 year old. Without the alt the batteries are at 12.6v
Alt output at the post on the back of the alt (which connects to the batteries) shows only 6v at idle, can't test at rpms until the wife comes home to rev the engine.
post #4 of 8 (permalink) Old 04-22-2008, 10:46 PM
bockhold's Avatar
Send a message via AIM to bockhold
alt
sounds like the alt or the regulator is going out. while running at idle, the alt should be putting out at lease 13v. if the alt gets replaced replace the regulator also at the same time. One night driving home from Dallas (the trip was like hrs one way) the alt light was a steady glow. We just replaced the external regulator be for that trip. Turns out the old alt burnt out the new reg and end up replacing the alt and regulator at the same time. Haven't had that problem since.
2006 F250 XLT CCSB 5r110 FX4
bockhold is offline
post #5 of 8 (permalink) Old 04-23-2008, 02:31 PM
Jcart's Avatar
On my '96 there is a small square electrical plug on the top of the Alernator which "plugs" down into the alternator. This plug on mine would wiggle and over time get dirty, upon cleaning contacts and a very small wipe of dialectric grease to improve contact it's fine....
jrc
97 XLT F250 CC ZF-5 (now
) DIY short shifter 355's D60 air locked T Wildman files, 'jectors, SD Hpop, 6.0 fan, IC, DP 4" exhaust, SS resonator, RSK, SD springs all corners, Velvet rides, Custom Aluminum Drybox/fuel tank, air bags, E-air compressor, VisionX HID/LED's, E fuel, F26D rear tank, 200 amp alternator, 1500 watt inverter.
Jcart is offline
post #6 of 8 (permalink) Old 04-23-2008, 03:14 PM Thread Starter
will check the single plug - thanks.
post #7 of 8 (permalink) Old 04-24-2008, 06:27 PM Thread Starter
no change with cleaning the plugs. Does 6v at idle but just above 1000rpms it goes to 12volts output. I ordered a new alt from rockauto.com for $130 shipped. We'll see if that cures it...I do believe it is the original alt so it owes me nothing!
post #8 of 8 (permalink) Old 04-25-2008, 07:44 PM
bockhold's Avatar
looks like the alt or the reg is going out.
bockhold is offline
